Seahorse Posted November 21, 2013 Share Posted November 21, 2013 I have drawn a part in mm in model space that is relatively small (50x50mm) and I drew in model space at a 1:1 scale with mm set as my units. However when I go into paper space and set my scaling which should be in the neighborhood of 3:1 instead it fits at 1:8. It appears to me that in paper space it interprets my 50mm as 50inches and "scales down" what is already a small object. Thanks for any help. (Woo first post) Quote Link to comment Share on other sites More sharing options...
nestly Posted November 21, 2013 Share Posted November 21, 2013 Welcome to Cadtutor. Your analysis sound about right to me. Do you know if you started the dwg with an imperial template, or a metric template? (acad.dwt vs acadiso.dwt) ie were 3:1 & 1:8 already on the scale list, or where they imperial scales such as 1" = 1'-0"? Quote Link to comment Share on other sites More sharing options...
rkent Posted November 21, 2013 Share Posted November 21, 2013 What are the dims of the title block? If you used an imperial title block then the viewport won't be large enough for your expected scale to work. Quote Link to comment Share on other sites More sharing options...
Seahorse Posted November 21, 2013 Author Share Posted November 21, 2013 Welcome to Cadtutor. Your analysis sound about right to me. Do you know if you started the dwg with an imperial template, or a metric template? (acad.dwt vs acadiso.dwt) ie were 3:1 & 1:8 already on the scale list, or where they imperial scales such as 1" = 1'-0"? I forgot which one I made the template with but I'd guess imperial. The 3:1 and 1:8 were on the scale were there already but so were the inches and feet scalings. Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 21, 2013 Share Posted November 21, 2013 The imperial template, acad.dwt, is the AutoCAD default. The metric template many users prefer is acadiso.dwt. Once you have made that your selection AutoCAD should default to it the next time you start a new drawing and every time after until you change it again. You still have the option of converting your present drawing to metric units using the -DWGUNITS command. Quote Link to comment Share on other sites More sharing options...
nestly Posted November 21, 2013 Share Posted November 21, 2013 If you created an metric drawing in an Imperial template, IMO the easiest fix is to open both your drawing, and the acadiso.dwt template and copy/paste from one to the other. Quote Link to comment Share on other sites More sharing options...
