Results 1 to 9 of 9
    Senior Member SAFeSTeR's Avatar
    SAFeSTeR's Computer Details
    W7 64-bit
    Intel Xeon @ 3.20Ghz
    12 GB
    Utilities
    SAFeSTeR's Discipline Details
    CAD Technician
    Utilities
    Water main replacement schemes.
    AutoCAD 2016
    Jul 2012
    Bristol, England
    258
    Default Text in dynamic block (rotation)
    Hi,
    I'm just trying my hand at learning to create some dynamic blocks, but need a solution to keep the text unrotated. I have attached a file of my troublesome file for you experts to look at, if possible.
    PileTest.dwg
    The file is basically a plan view of 4x foundation columns for overhead line towers (pylons). These towers can be different sizes and at different orientations, hence the dynamic options I have applied. However, when I rotate the block I want the text to rotate with it (to keep aligned with each column A, B, C, D), but I don't want rotation to be applied to the text, if that makes sense?
    Any ideas on the best way to achieve this? I have a feeling that constraints might work, although I know nothing about them, but these usually lag my PC. At present I am having to explode the block and apply a 0 rotation to all the text.
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,140
    Read post #8 in this thread, he gives you exactly what you need to accomplish what you're after:
    http://www.cadtutor.net/forum/showth...l=1#post331987
    This member helped me out back in 2010 with the same inquiry. It basically comes down to selecting the Move parameter applied to the Text, and not selecting the text itself. Chain Actions must be enabled as well. Hope this helps.
    - Tannar
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    W7 64-bit
    12 GB
    Utilities
    CAD Technician
    Utilities
    AutoCAD 2016
    Jul 2012
    Bristol, England
    258
    Great, will look into this soon
    Thanks.
    W7 64-bit
    12 GB
    Utilities
    CAD Technician
    Utilities
    AutoCAD 2016
    Jul 2012
    Bristol, England
    258
    Unfortunately this didn't help me much in my example.
    The first time I tried it the text rotated with each foundation, but they remained in the same orientation, i.e., in the NE, SE, SW, NW positions as they are shown in my example link. I need them to rotate with the tower legs (A, B, C, D) but remain in a 0 rotation themselves.
    So I tried again and it got even worse. The text rotated, but again in the manner described above, however, the foundations seemed to rotate around a completely different axis point and separated from the text until I got back to the original point (360 degrees).
    I guess I will need to think about this and experiment with different dynamic setups, even if I don't achieve the desired result I should hopefully teach myself some new.
    Until then it will be easier for me just to stick to my original method of exploding and manually applying 0 rotation to the text.
    Thanks anyway guys.
  5. #5
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,140
    I now see the results you're after.
    This is just me thinking out loud but I wonder how the text would react with two rotate parameters - one that's already in place which controls the entire set of objects, then four more, each controlling the text around the corresponding column. Never tried it but seems like it might work.
  6. #6
    W7 64-bit
    12 GB
    Utilities
    CAD Technician
    Utilities
    AutoCAD 2016
    Jul 2012
    Bristol, England
    258
    Yep, that is the kind of thing I want to experiment with. I'm not sure that will work but some kind of combination might.
  7. #7
    Super Member Tuns's Avatar
    Tuns's Computer Details
    Windows 7 (64-bit)
    Intel Core I3-2120
    4.0 GB
    AutoCAD LT 2014
    Jun 2013
    San Antonio, Texas
    784
    That's pretty much what I just did here.
    Never argue with an idiot. He will drag you down to his level and beat you with experience.
  8. #8
    W7 64-bit
    12 GB
    Utilities
    CAD Technician
    Utilities
    AutoCAD 2016
    Jul 2012
    Bristol, England
    258
    Thanks, but can you save in 2010 format please?
  9. #9
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,165
    It should work as described in the thread given by Tannar in post #2 above, shown in leg B in the attached drawing, you do need to be careful what is and isn't selected, and where things are placed, and that parameters are chained, and that actions are not selected and parameters are , and that text is only selected with the move actions. Other than that it's a piece of cake
  1. Dynamic Block Rotation
    By RFRUSSO in forum AutoCAD Drawing Management & Output
    Last Post: 31st Mar 2014, 04:23 pm
  2. Dynamic block with Atribute rotation
    By notkathrine in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Nov 2013, 08:31 pm
  3. Attribute rotation in dynamic block
    By JeepMaster in forum AutoCAD Drawing Management & Output
    Last Post: 16th Jan 2013, 03:12 pm
  4. Dynamic Block - Rotation Parameter and Text
    By tzframpton in forum AutoCAD General
    Last Post: 26th Jul 2012, 05:24 pm
  5. Dynamic Block - Keep Text same rotation
    By guitarguy1685 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 12th Jul 2011, 06:11 pm
Tags for this Thread
