madriver Posted November 27, 2013 Share Posted November 27, 2013 When I drag a previous custom command into an existing custom tool bar and edit the custom command (then rename the command in the Name and Command Name) it also changes the previous custom command that I originally drug into the toolbar. What am I doing wrong? Thanks BA Quote Link to comment Share on other sites More sharing options...
nestly Posted November 27, 2013 Share Posted November 27, 2013 When you drag it from the command list, it's still linked back to the command in the command list. If it needs a to be a different (even if only renamed) create a new command in the command list and drag that one to the new toolbar. Quote Link to comment Share on other sites More sharing options...
Tuns Posted November 27, 2013 Share Posted November 27, 2013 What you're doing is editing the exact same command as you had before. It updates the toolbar as well as the command you made every time you change it. You have to make new commands every time you want to add to the tool bar. Quote Link to comment Share on other sites More sharing options...
