cadman2012 Posted November 30, 2013 Share Posted November 30, 2013 is there any command to fit or re-size a title block to A drawing in the layout Quote Link to comment Share on other sites More sharing options...
Dana W Posted November 30, 2013 Share Posted November 30, 2013 Is your title block an "inserted block" or is it simply drawn on the layout? Have you tried the Scale command? Quote Link to comment Share on other sites More sharing options...
cadman2012 Posted November 30, 2013 Author Share Posted November 30, 2013 it is inserted block & i usually use scale to re size it but i was asking if there is any command to fit or re-size a title block to A drawing in the layout so i can do it in one step to reduce my working time & finish as quick as possible can you help & thanks for the quick response Quote Link to comment Share on other sites More sharing options...
Murph_map Posted November 30, 2013 Share Posted November 30, 2013 it is inserted block & i usually use scale to re size it but i was asking if there is any command to fit or re-size a title block to A drawing in the layout so i can do it in one step to reduce my working time & finish as quick as possible can you help & thanks for the quick response Use templates, once you create a layout with the title block scales/sized for the sheets you can save that layout (LAYOUT typed on the command line) as a template then when you need that size layout again you can create it by right clicking on the layout tab. Quote Link to comment Share on other sites More sharing options...
cadman2012 Posted December 1, 2013 Author Share Posted December 1, 2013 thank you for your help every one Quote Link to comment Share on other sites More sharing options...
