davesec Posted December 3, 2013 Share Posted December 3, 2013 i tried searching for this because i imagine it's probably already been addressed, but does anyone have any tips on how to properly select a hatch? i find i'm constantly skimming my mouse all over the hatch trying to find a spot where i can actually select it... sometimes it's super super precise, and if i move my mouse even a tiny bit off it'll disappear... thanks Quote Link to comment Share on other sites More sharing options...
CADgirl Posted December 3, 2013 Share Posted December 3, 2013 Usually for me it works best to try and select it from the center. Somehow it doesn't really pick it up from the edge. Quote Link to comment Share on other sites More sharing options...
davesec Posted December 3, 2013 Author Share Posted December 3, 2013 i find it's usually somewhere in between the middle and the edge. longer rectilinear shapes (L-shapes, E-shapes etc) usually can be picked up in the bend or hinge between the two rectangles. But it can be really difficult sometimes! Quote Link to comment Share on other sites More sharing options...
rkent Posted December 3, 2013 Share Posted December 3, 2013 Are you talking about Solid hatching? If so change it to something like ANSI31, later change it back. Quote Link to comment Share on other sites More sharing options...
bbankston Posted December 3, 2013 Share Posted December 3, 2013 I've thought the same thing, davesec. I only have that problem, of course, with the solid hatch. Sadly, I do not have an answer. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted December 3, 2013 Share Posted December 3, 2013 Is Selection Cycling available in 2009? Also, you can always use the Filter tool and save the selection set for future use. Quote Link to comment Share on other sites More sharing options...
mikekmx Posted December 3, 2013 Share Posted December 3, 2013 if i have probs selecting a hatch, i try click/left-dragging with the mouse, selecting the hatch & the boundary, then de-selecting the boundary (shift & click) Quote Link to comment Share on other sites More sharing options...
Organic Posted December 4, 2013 Share Posted December 4, 2013 I often have an issue with this as well. Hovering the mouse near the centre of the hatch does normally work, if not I use quick select. Quote Link to comment Share on other sites More sharing options...
SuperCAD Posted December 4, 2013 Share Posted December 4, 2013 Do a right-to-left box selection to grab the hatch and part of the boundary. Then right click and use Quick Select, change your object type to Hatch, and you can either specify exactly what hatch pattern you're trying to select or you can change the operator to select all. Quote Link to comment Share on other sites More sharing options...
Tuns Posted December 4, 2013 Share Posted December 4, 2013 I don't have this problem with any hatch. I just window a small portion of it and it selects it. If it's solid I click the hatch anywhere and that does it for me. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted December 4, 2013 Share Posted December 4, 2013 I don't have this problem with any hatch. I just window a small portion of it and it selects it. If it's solid I click the hatch anywhere and that does it for me.AutoCAD 2014 does work much better with solid hatches. The O.P. is using 2009. Quote Link to comment Share on other sites More sharing options...
Tuns Posted December 4, 2013 Share Posted December 4, 2013 Well I remember using 2002 and having no problems. Did they change something in between 2002 and 2009? Quote Link to comment Share on other sites More sharing options...
davesec Posted December 4, 2013 Author Share Posted December 4, 2013 i'm actually using 2011 right now, and also have 2013 on some other machines here at work.. i'm trying a solid hatch in a rectangle, and it looks like to grab the hatch, i have to move my mouse over the imaginary diagonal line that goes from the upper left corner to lower right... anywhere else and i can't select the hatch. Quote Link to comment Share on other sites More sharing options...
SAFeSTeR Posted December 4, 2013 Share Posted December 4, 2013 I don't really have a problem selecting a hatch, as long as I click on one of the visible parts. Quote Link to comment Share on other sites More sharing options...
