prakashreddy Posted December 5, 2013 Share Posted December 5, 2013 Dear all, I am drawing some dimensions by changing UCS, because of this i am getting dimension text as reversed. To change that text i used mirror 3d command. If i am using mirror 3d for the fourth time i am getting error like these... "FATAL ERROR: commands may not be nested more than 4 deep" (command "_.MIRROR3D" ss "" "0,0,0" "0,1,0" "1,0,0" "_Y") any other solution is there.... Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 5, 2013 Share Posted December 5, 2013 Use the AutoLISP function version of MIRROR3D: http://exchange.autodesk.com/autocad/enu/online-help/ARCHDESK/2012/ENU/pages/WS1a9193826455f5ff1a32d8d10ebc6b7ccc-673c.htm You first need to ensure that the geom3d ARX application is loaded. Quote Link to comment Share on other sites More sharing options...
prakashreddy Posted December 6, 2013 Author Share Posted December 6, 2013 Thanks Mr. Lee Is any problem if i load geom3d ObjectARX? http://www.processlibrary.com/en/directory/files/geom3d/435514/ Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 6, 2013 Share Posted December 6, 2013 Is any problem if i load geom3d ObjectARX? No, just use something like: (if (not (vl-some '(lambda ( x ) (wcmatch (strcase x) "GEOM3D*")) (arx))) (arxload "geom3d") ) Quote Link to comment Share on other sites More sharing options...
