Results 1 to 4 of 4
    Forum Newbie
    AutoCAD 2013
    Dec 2013
    1
    Default HOw to Export GPS Coordinates to CSV
    Dear All,
    Good Day,
    I am looking for a method to export all the GPS coordinates which have been assigned to each point along with the properties of that point to an excel csv.
    In our drawings, there are multiple columns and each column has four points and each point has X,Y,Z coordinates. I want to export all this information to an excel sheet.
    Any idea?
    Thank You
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    One possibility might be the DATAEXTRACTION command.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,127
    Have a look at "Similar Threads" at the bottom of this page.
    This one Export Coordinates from AutoCAD Help may help.
    Senior Member satishrajdev's Avatar
    satishrajdev's Computer Details
    Windows 7 - 64bit
    DELL
    8 GB
    500 GB
    DELL
    Surveying
    satishrajdev's Discipline Details
    CAD Engineer
    Surveying
    Design Survey Utilities (i.e. Bathymetry & Geophysical Survey) Design of Survey Planning. Preparation of Alignment Sheets. Programming in AutoCAD.
    AutoCAD 2014
    Apr 2012
    Aamchi Mumbai, India
    451
    Try this :-
    Code:
    (Defun C:ExportPMT (/ *error* Smode file dta i theEntity eb pnt    txv)
      (setvar "cmdecho" 0)
      (Defun *error* (msg)
        (if    (not (member msg
                 '("bad argument type: lselsetp nil"
                   "bad argument type: stringp nil"
                   "quit / exit abort"
                   "Function cancelled"
        (prompt
          "\n........................................................"
        (princ "\nStatus : Function cancelled")
      (prompt
        (strcat "\n:: Routine created by Satish Rajdev. ::")
      (initget 1 "P T")
      (setq Smode (getkword "\nSelect Mode ('P'Point/'T'Text or Mtext):"))
      (setq
        file (open (getfiled "Specify Output XYZ File" "c:/" "CSV" 1)
               "w"
      (if (= Smode "P")
          (write-line
        "Easting (mE),Northing (mN),Elevation (m)"
        file
          (while (= dta nil)
        (setq dta (ssget '((0 . "POINT")))
        (if (= dta nil)
          (alert "Please select POINTS to continue...")
          (repeat (setq i (sslength dta))
        (setq theEntity (ssname dta (setq i (1- i))))
        (setq eb (entget theEntity))
        (setq pnt (cdr (assoc 10 eb)))
        (setq txv (rtos (caddr pnt) 2 3))
        (write-line
          (strcat (rtos (car pnt) 2 3)
              (rtos (cadr pnt) 2 3)
              txv
          file
          (close file)
          (setq msg "CSV File is created with extracted POINT details")
          (alert msg)
      (if (= Smode "T")
          (write-line
        "Easting (mE),Northing (mN),Text Value"
        file
          (while (= dta nil)
        (setq dta (ssget '((0 . "TEXT,MTEXT")))
        (if (= dta nil)
          (alert "Please select Text/Mtext to continue...")
        (setq txv (cdr (assoc 1 eb)))
        (write-line
              txv
          file
          (close file)
          (setq msg "XYZ File is created with extracted TEXT/MTEXT details")
          (alert msg)
      (prompt
      (prompt (strcat "\nStatus : " msg))
      (setq *error* nil)
      (setvar "cmdecho" 1)
    (princ
      "\n:: Type \"ExportPMT\" to Run the Routine ::"
    Best Regards,
    Satish Rajdev
    If you ride like there is no tomorrow... Don't worry, there won't be !!!!
    www.facebook.com/satish.rajdev
  1. Export coordinates and blockname to excel
    By Wouter543 in forum AutoCAD Beginners' Area
    Last Post: 21st Mar 2012, 03:28 pm
  2. Export Coordinates from AutoCAD Help
    By Kcks in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th Nov 2010, 11:25 am
  3. Export from Revit to 3ds Max loses coordinates
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 4th Nov 2010, 02:30 am
  4. Export points coordinates and the text near it...
    By digitalghost in forum AutoCAD General
    Last Post: 30th Nov 2007, 04:52 pm
  5. How can I export X, Y coordinates of objects??
    By acatalin2003 in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Oct 2005, 07:32 pm
Tags for this Thread
