Missing plot styles
Butch
Hi guys!
Im using ACAD 2011.
I had to send my client an .pdf drawing.
When I went to plot my drawing using the .dwg to .pdf all of my plot stlyes have dissapeared :-(
Ive been trying to get them back but I have no idea what happend and what to do.
In the attached image you can see ho all of the styles are gone...
How to return them?
upload pictures online
  • Replies 21
  • ReMark
    11
  • Butch
    11
Popular Days
Maybe the path to the plot styles is missing. Did you check?
Options > Files > Printer Support File Location > Plot Style Table Search Path. Anything showing?
Yeap if I double click the "Plot Style Table Search Path" I can see the path
C:\Users\myname\appdate\roaming\autodesk\autocad 2011\r18.1\enu\plot styles
That's a start.
Now copy the path and put it in Explorer so you can browse the contents of the folder to determine what is or isn't there.
Well I was thinking more like a network one would find at work.
Then it isn't a case of the path being wrong or someone (IT person) moving the folder.
Were you rooting around in AutoCAD folders for some reason?
Alright...different approach.
Using Explorer look under Program Files > AutoCAD 2011 > UserDataCache > Support > Plotters > Plot Styles. Do you see the files there? There should be 13 of them.
Well you should have a UserDataCache right where I said it would be found unless you deleted it. These things don't up and delete themselves. Are you sure you looked in the right location?
Type STYLESMANAGER at the command prompt and press Enter. What, if anything, appears on your screen?
Do a REPAIR of your installation. Do NOT uninstall AutoCAD as there is no need to. The REPAIR should fix the missing items.
Did you try resetting your Profile?
