SAFeSTeR Posted December 12, 2013 Share Posted December 12, 2013 I'm trying to add some attributes to an existing block using the block editor, but after I save and close it I cannot see any 'placeholders' despite adding a default value and the attributes work fine when I double click the block. I've tried using the ATTSYNC and BATTMAN commands but nothing helps and there are no invisibilty states applied to either the attribute or block and all layers are switched on. I just tried making a quick block from scratch and it seems to have the same affect, except the default value will show, but no 'placeholder' shown if left blank. I swear with previous version I could see the tag when a value hadn't been applied, so is it that the version I now use (2012) does not have this feature or it's disabled? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
resullins Posted December 12, 2013 Share Posted December 12, 2013 There aren't placeholders in a block, just default values, so that if you go in to edit the att, it will give you something in your dialogue box. I can't remember how previous versions handled this... but I know 2012 doesn't show them. If you double click your block and the attributes are there, then you're doing everything right... but no, your default value won't show up when the block is inserted. Quote Link to comment Share on other sites More sharing options...
resullins Posted December 12, 2013 Share Posted December 12, 2013 And actually, I take that back. I just noticed I have both reactions happening in some of my blocks. Whoops. Interesting. Quote Link to comment Share on other sites More sharing options...
Tuns Posted December 12, 2013 Share Posted December 12, 2013 Did you try re-inserting the block? Quote Link to comment Share on other sites More sharing options...
dbroada Posted December 12, 2013 Share Posted December 12, 2013 That is working how I would expect. I have never seen a "placeholder" for a blank attribute. This is the reason I don't favour title blocks with no graphical element to double click on. There may be a variable somewhere to change the behaviour but I don't know of it. Quote Link to comment Share on other sites More sharing options...
SAFeSTeR Posted December 13, 2013 Author Share Posted December 13, 2013 OK, thanks for your help. I just thought that the attribute tag would be visible if the value was blank (that's all I meant by placeholder) as a visual representation that attributes were present, guess I was wrong. Still, I would have expected the default value to show for the very same reason. Quote Link to comment Share on other sites More sharing options...
steven-g Posted December 13, 2013 Share Posted December 13, 2013 The default value should show, it may need the ATTSYNC command if you are adding attributes, but if you have put in a default value that should show up. Are you sure the property of the attribute isn't set to invisible. Quote Link to comment Share on other sites More sharing options...
dbroada Posted December 13, 2013 Share Posted December 13, 2013 I have just done a quick test here adding an ATTDEF with a default to an existing block. My test showed that the default will only show on existing blocks when an ATTSYNC has been applied, although (obviously) any new instances will show the new attribute. Quote Link to comment Share on other sites More sharing options...
SAFeSTeR Posted December 13, 2013 Author Share Posted December 13, 2013 There are no invisibility states present, but unlike yesterday, the ATTSYNC command is helping, so all seems fine. Thanks guys Quote Link to comment Share on other sites More sharing options...
dbroada Posted December 13, 2013 Share Posted December 13, 2013 ah, the mysterious "I'm not behaving" bug that afflicts AutoCAD so often. Glad you're sorted. Quote Link to comment Share on other sites More sharing options...
