tennis4you Posted December 16, 2013 Share Posted December 16, 2013 The last few days when I open or close AutoCAD it is locking up for about 30-40 seconds. Once I have it open and I am moving between files I am fine. When I do open AutoCAD, it is either with just the AutoCAD icon or maybe through various fils. Any reason for the pause? Thanks! Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted December 16, 2013 Share Posted December 16, 2013 It could be any number of things. If you feel like diagnosing this yourself, here are some tips. Quote Link to comment Share on other sites More sharing options...
tennis4you Posted December 16, 2013 Author Share Posted December 16, 2013 I tried using that program. It downloaded OK, I got through the steps to fire open AutoCAD and watch the info flow, but nothing happened. ;( Quote Link to comment Share on other sites More sharing options...
SLW210 Posted December 17, 2013 Share Posted December 17, 2013 What do you mean by "nothing happened"? AutoCAD didn't start? You didn't see any processes? Quote Link to comment Share on other sites More sharing options...
tennis4you Posted December 17, 2013 Author Share Posted December 17, 2013 Sorry for the lack of information. AutoCAD opened. I tried it a few times. Sometimes it froze, sometimes AutoCAD opened without freezing. The program itself did nothing. From what I was reading it should have started to generate a list but no list ever appeared. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted December 17, 2013 Share Posted December 17, 2013 Sorry for the lack of information. From what I was reading it should have started to generate a list but no list ever appeared. If by "the program", you mean "Process Monitor", make sure the buttons shown here are "active" (or enabled/turned on) Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 17, 2013 Share Posted December 17, 2013 Maybe AutoCAD is looking for something. Do you have an extra, extra path to some folder? Quote Link to comment Share on other sites More sharing options...
tennis4you Posted December 19, 2013 Author Share Posted December 19, 2013 Both buttons are on/enabled, it is still not working. ;( Does 64 bit affect it? Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 19, 2013 Share Posted December 19, 2013 I have it working on a 64-bit system at this very moment. OS: Win7 Ultimate. Quote Link to comment Share on other sites More sharing options...
tennis4you Posted December 19, 2013 Author Share Posted December 19, 2013 (edited) Interesting. I am the same exact setup, OS Win7 Ultimate. I have tried it a few times and nothing ever happens. The setup portion went well, I believe I followed the instructions, I just cannot get it to do anything when AutoCAD opens. It happens a lot when I first open a file or close a file. Typically once I am in AutoCAD things go smooth. For example, I just opened a new file. Clicked on on of the layout spaces and it locked up for 25 seconds. New files have no xrefs in them. Thanks! Edited December 20, 2013 by tennis4you Quote Link to comment Share on other sites More sharing options...
tennis4you Posted December 19, 2013 Author Share Posted December 19, 2013 acadlt.exe worked. I see the mega list, I even got AutoCAD to freeze up on me, but I did not see anything in the list that the Process Monitor found to be broken (like a missing path or something). Running out the door. Will try again this afternoon. At least I have the program working now. Quote Link to comment Share on other sites More sharing options...
tennis4you Posted December 20, 2013 Author Share Posted December 20, 2013 OK, I have run the program and looked at the results, but I am not sure where to take it from here. I have several "Results" that say "Name Not Found" instead of "Success". Are those the issue? There are various ones. There were other ones that said "File Locked with Only Readers" as well. Thank you, Quote Link to comment Share on other sites More sharing options...
Dana W Posted December 20, 2013 Share Posted December 20, 2013 Are you working on a network? Do you have xrefs in your drawing that are not where their original path says they are? If you have xrefs in your drawing, are other people working on those drawings? Quote Link to comment Share on other sites More sharing options...
tennis4you Posted December 20, 2013 Author Share Posted December 20, 2013 I do work off of a server, but the xrefs are where they say they are. The server sits in my house and I have one other person that works here with me. There are a few people who work remote for me, but I am in files they have never touched. Quote Link to comment Share on other sites More sharing options...
Dana W Posted December 21, 2013 Share Posted December 21, 2013 You said it happens most often when opening or closing a file. You may just be waiting for access to the network. Your server may be a little light or under maintained for the stress you all are giving it. Have you tried copying one of the files to your "C" drive to test it for pausing behavior there? Quote Link to comment Share on other sites More sharing options...
tennis4you Posted December 21, 2013 Author Share Posted December 21, 2013 When opening AutoCAD it is not accessing the server, it is just opening a new file that has not yet been saved to the server. Only 2 people use the server so my hunch is the server is not being overloaded, plus we all have smaller files. I will copy some files to the C Drive and test it though. Still would be interested to know what I can do with all the information the Process Monitor pumped out. Quote Link to comment Share on other sites More sharing options...
Dana W Posted December 21, 2013 Share Posted December 21, 2013 Well, since you said you work off a server, I went with that. I'll bow out and let the experts help you with this. Quote Link to comment Share on other sites More sharing options...
tennis4you Posted January 3, 2014 Author Share Posted January 3, 2014 Anyone have any thoughts on what I can do with the information Process Monitor is giving me? It's a ton of information and I am not sure how to process it all. AutoCAD is still locking up on me and is chewing up a good portion of time. Quote Link to comment Share on other sites More sharing options...
Tuns Posted January 3, 2014 Share Posted January 3, 2014 Why not process it in smaller bits? Who said you had to do it all at one time? Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 3, 2014 Share Posted January 3, 2014 When AutoCAD locks up on you are you seeing an increase in hard drive activity? Do you know if you have file indexing enabled? Quote Link to comment Share on other sites More sharing options...
