Gentile Romano Posted December 24, 2013 Share Posted December 24, 2013 Dear All; 300 is one of the text object, the other text object is 1215/LP/300 Example: If I change the above text to 100, the below text should change 1215/LP/101 I want to link the text object values as shown Image attached I think this is enough explained...... Thanks Romano Merry Happy Christmas Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 24, 2013 Share Posted December 24, 2013 Seems like you want to increment a number but your example (100 to 101), expressed in words, does not appear to agree with what you say in the attached image (300 to 301). Which is it? Is 1215/LP/300 an attributed block? Have you tried searching on.... "diesel expression"+"increment" ...to find examples of diesel macros that increment numbers? Quote Link to comment Share on other sites More sharing options...
Gentile Romano Posted December 24, 2013 Author Share Posted December 24, 2013 Dear All; I think this is enough explained...... Thanks Romano Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 24, 2013 Share Posted December 24, 2013 Did you try the recommended search? I did and I found at least three results where incrementing a number was discussed as part of the macro. Quote Link to comment Share on other sites More sharing options...
steven-g Posted December 24, 2013 Share Posted December 24, 2013 You need to use a formula in your field, select formula in the left hand column and in the formula box right click and choose insert field again. This time select object from the list on the left and then pick your text object that contains 300,pick the contents property (and click OK once), back in the formula add in "+1", that's it. If you change the value of the 300 text you will need to do a regen but the field will update accordingly. Quote Link to comment Share on other sites More sharing options...
Gentile Romano Posted December 24, 2013 Author Share Posted December 24, 2013 Hi all; I got it, thanks steven Thank you all replied to my thread for your love and support! Best Regards Romano Quote Link to comment Share on other sites More sharing options...
