notview Posted December 26, 2013 Share Posted December 26, 2013 I discovered that using JUSTIFYTEXT on the command line was give me different result if compared to TEXT JUSTIFY using the TEXT PROPERTIES. To elaborate the difference, if I select 3 (objects) text and Justify to Left (origin from Center Aligned), using TEXT PROPERTIES the results were all the 3 text positioned and aligned to the Left & make it LEFT Justify. While using JUSTIFYTEXT on the command line, the results were only make it LEFT Justify but the position were not change. I prepared using JUSTIFYTEXT on the command line but I WANT are to give me same result as using TEXT PROPERTIES. What should I do? Any help will be appreciated!! Quote Link to comment Share on other sites More sharing options...
RobDraw Posted December 30, 2013 Share Posted December 30, 2013 I would use the one that works the way you want it to. Quote Link to comment Share on other sites More sharing options...
