Results 1 to 10 of 10
    Full Member
    AutoCAD 2017
    Dec 2013
    26
    Default Help shading a circular area with entmake hatch
    I am working off of this code cadpanacea.com/node/186, but when I try to run the following, the radius of the circular hatch varies based on the 'ctr' variable's distance from the origin. I would like it to depend solely on the 'ctr' and 'edge' points.
    Code:
    (defun c:test()(setvar "osmode" 0)
    (setq ctr (getpoint "\nCenter of Circle: "))
    (setq edge (getpoint "\nEdge of Circle: "))
    (entmakex (list
      (cons 0 "HATCH")
      (cons 100 "AcDbEntity")
      (cons 8 "E-GRND")
      (cons 100 "AcDbHatch")
      (cons 10 ctr)
      (cons 210 (list 0 0 1))
      (cons 2 "SOLID")
      (cons 70 1)
      (cons 71 0)
      (cons 91 1)
      (cons 92 1)
      (cons 93 1)
      (cons 72 3)                        ;the "3" designates this is an elliptical shape, 1 for circle
      (cons 10 ctr)                      ;center point of ellipse
      (cons 11 edge)                     ;point of top quad
      (cons 40 1)                        ;ratio of width to height
      (cons 50 0.0)                      ;start angle
      (cons 51 (* pi 2.0))               ;end angle (full ellipse)
      (cons 73 1)                        ;counterclockwise flag
      (cons 97 0)
      (cons 75 0)
      (cons 76 1)
      (cons 98 1)
      (cons 10 (list 0 0 0))
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,572
    Try the following:
    Code:
    (defun c:test ( / cen ocs rad )
        (if
            (and
                (setq cen (getpoint "\nCenter: "))
                (setq rad (getdist cen "\nRadius: "))
                (setq ocs (trans '(0.0 0.0 1.0) 1 0 t))
            (entmake
                (list
                   '(000 . "HATCH")
                   '(100 . "AcDbEntity")
                   '(100 . "AcDbHatch")
                   '(010 0.0 0.0 0.0)
                    (cons 210 ocs)
                   '(002 . "SOLID")
                   '(070 . 1)
                   '(071 . 0)
                   '(091 . 1)
                   '(092 . 0)
                   '(093 . 1)
                   '(072 . 2)
                    (cons 010 (trans cen 1 ocs))
                    (cons 040 rad)
                   '(050 . 0.0)
                    (cons 051 (+ pi pi))
                   '(073 . 1)
                   '(097 . 0)
                   '(075 . 0)
                   '(076 . 1)
                   '(098 . 1)
    The above should also work in all UCS & Views.
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    Senior Member ymg3's Avatar
    not applicable
    May 2011
    414
    Try this function:
    To obtain circle call with (pwipeout ctr rad 30)
    Code:
    ;; Polygonal Wipeout  -  Lee Mac                                              ;
    ;; Creates an n-sided Polygonal Wipeout with the given center (UCS) & radius  ;
    ;; Modified by ymg                                                            ;
    (defun pwipeout ( cen rad n / ang inc lst )
        (setq inc (/ pi n 0.5)
              ang (* (/ pi 2) -1)
        (repeat n
            (setq lst (cons (list 14 (* 0.5 (cos ang)) (* 0.5 (sin ang))) lst)
                  ang (+ ang inc)
        (entmakex
            (append
                (list
                    (cons 0 "WIPEOUT")
                    (cons 100 "AcDbWipeout")
                    (cons 10 (trans (mapcar '- cen (list rad rad)) 1 0))
                    (cons 11 (trans (list (+ rad rad) 0.0) 1 0 t))
                    (cons 12 (trans (list 0.0 (+ rad rad)) 1 0 t))
                    (cons 280 1)
                    (cons 71 2)
    	        (cons 91 (1+ (length lst)))
                (cons (last lst) lst)
    Full Member
    AutoCAD 2017
    Dec 2013
    26
    Thank you both, I've got it working now!
  5. #5
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,572
    Quote Originally Posted by plackowski View Post
    Excellent - you're welcome plackowski!
  6. #6
    Junior Member
    Construction
    Quest for Peace's Discipline Details
    Engineer, VP
    Construction
    Electrical
    AutoCAD 2015
    Sep 2011
    Sacramento, CA
    24
    On Lee's test program, thread post #2, I need to make a half circle (solid hatch). But I can't make it work.
  7. #7
    Super Member hanhphuc's Avatar
    AutoCAD 2007
    Apr 2013
    Happy Garden
    722
    hi
    Code:
    (cons 051 (+ pi  pi ))
    replace to
    Code:
    (cons 051 pi )
    HTH , all credit to Lee Mac
    this is an alternative solid half-circle
    Code:
    (defun c:test (/ p r v)
    (setq v (getvar "osmode"))
      (if (and (setq p (getpoint "\nPick center: "))
    	   (setq r (getdist p "\nRadius: ")))
        (command "_pline" p "w" r r "arc" (mapcar '+ p (list 0. r 0.)))
        ) ;_ end of if
      (if (= (getvar "cmdactive") 1)
        (command)
        ) ;_ end of if
    (setvar "osmode" v)
      ) ;_ end of defun
    _$ ( apply 'equal "hp" "happy" "hạnh phúc" "ハッピー" "幸福" "행복" )
    ; error: too many arguments
  8. #8
    Junior Member
    Construction
    Engineer, VP
    Construction
    Electrical
    AutoCAD 2015
    Sep 2011
    Sacramento, CA
    24
    I can't get it. I put this on the 'back-burner' for 3months now, coming back to it occasionally. The semi-circle needs a flat vertical edge that does not go through the center point.
    This is what I have, started from a similar hatch that works. This doesn't make anything. What is the minimum definition? And I also need the mirror image of it, will that be apparent?
    Code:
    (entmake
        '((0 . "hatch")(100 . "AcDbEntity")(8 . "0")(62 . 0)(6 . "ByBlock")
    (100 . "AcDbHatch")(10 0.0 0.0 0.0)(210 0.0 0.0 1.0)(2 . "SOLID")
    (70 . 1)(71 . 0)(91 . 1)(92 . 1)(93 . 4)
    (72 . 1)(10 3.8301 15.3204 0.0)(11 3.8301 4.55836 0.0)
    (72 . 2)(10 1.91505 9.97494 0.0)(40 . 5.74515)(50 . 5.05223)(51 . 1.23096)
    (73 . 1)(97 . 0)(75 . 0)(76 . 1)(98 . 1)(10 0.0 0.0 0.0)(450 . 0)(451 . 0)
    (460 . 0.0)(461 . 0.0)(452 . 0)(462 . 0.0)(453 . 0)(470 . "")))
  9. #9
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,572
    Please post a drawing showing the intended result.
  10. #10
    Junior Member
    Construction
    Engineer, VP
    Construction
    Electrical
    AutoCAD 2015
    Sep 2011
    Sacramento, CA
    24
    I wasn't sure how to do that. Here's a try. It's a controlled electrical receptacle symbol. I need one with both sides shaded and one with only one side shaded. Thanks for your help,
  1. Entmake of a Hatch
    By Quest for Peace in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd Nov 2011, 02:28 pm
  2. Entmake HATCH entity
    By CAD Panacea in forum AutoCAD RSS Feeds
    Last Post: 14th Oct 2010, 10:01 am
  3. Selecting Circular Area
    By vlsf1980 in forum AutoCAD General
    Last Post: 19th May 2009, 10:02 am
  4. Entmake Hatch
    By Lee Mac in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Apr 2009, 09:06 pm
  5. circular hatch?
    By Rebel in forum AutoCAD Drawing Management & Output
    Last Post: 18th Apr 2005, 10:04 pm
Tags for this Thread
