Switch sides that will be cut?
irishobo
Ok I have designed the gear and extruded it. I am now trying to cut the teeth into it. The cut selection under extrude will only allow me to cut the gear out and leaves the left over pieces. I need the gear not the pieces. Thanks in advance.
I haven't used inventor in a while but I think you have to hit the second box down in the middle of the dialog box. I'll check when I get home.
Yes it is the second button down. I was just illustrating the view i get. I am unable to cut the left over pieces out of the teeth. It cuts the whole gear out instead.
sorry I should have zoomed in farther I'm on my phone. Use the third button down its intersect. Or you could use the tool to create gears. the sketch you have is all you need for the profile of the gear. The solid in the background is not needed.
Edit: if it doesn't work hit the button with a plane with an arrow on it to extrude the shape the other direction and use the third button down.
The intersect worked beautifully thank you very much. I havent worked with the gear tool yet. It doesn't show up in the ribbon when building a part. I assume you have to build it in an assembly.
Glad I could help. I think the gear tool is in assembly, it's a little daunting at first but once you figure out what values you need it's really only a few inputs.
It looks like you have patterned a sketch rather than a feature.
There should be no need for repeating dimensions (or constraints).
That is almost always the wrong way. (Edit the sketch and right mouse button and select Show all Constraints. What do you see?)
Attach your *.ipt file here.
Show all constraints seems to show alot of problems.
Here is the *.ipt file.
I would appreciate any advice you have.
I will get back to this when I get a chance.
I don't normally go to 3rd party sites to download files.
For those who want to take a look - here is the file with the EOP rolled up.
There are a lot of improvements that can be made on this one.
JD
ETSU '03
JD
ETSU '03
Oh my apologies. Is there a way to upload it directly to you?
