gort ben Posted January 5, 2014 Share Posted January 5, 2014 I am switching over to Inventor 2010 from autocad ,how do you create a multiple parts file to use the combine command.I know it's probably simple but can't find it. Thanks. Quote Link to comment Share on other sites More sharing options...
Pablo Ferral Posted January 5, 2014 Share Posted January 5, 2014 Do you mean multiple bodies? Look for the 'new body' button In the shape creation tools. Quote Link to comment Share on other sites More sharing options...
gort ben Posted January 5, 2014 Author Share Posted January 5, 2014 Thanks got that sussed but can't get the copy demand to work, it's like starting from scratch. Quote Link to comment Share on other sites More sharing options...
mattador04 Posted January 5, 2014 Share Posted January 5, 2014 What are you trying to copy, precisely? You may want to be using an .iam and be placing .ipt's into it. I don't know if you know this, but AutoCAD and Inventor are two different animals. They both serve a purpose in their own right, however, and as such, Autodesk has facilitated interoperability between the two platforms. The primary difference is the 'parametric 3d environment' that you will experience with inventor. You create things as individual pieces (.ipt filetype), many pieces assembled and working together ( .iam filetype), drawings (.idw) and "presentations" (.ipn). Quote Link to comment Share on other sites More sharing options...
gort ben Posted January 6, 2014 Author Share Posted January 6, 2014 I am trying to copy a solid object in a part file Quote Link to comment Share on other sites More sharing options...
mattador04 Posted January 6, 2014 Share Posted January 6, 2014 Hmmmm, I know you can copy objects within a sketch, but when it comes to copying solid objects within an .ipt, that is not something that's usually done (for me anyway). What i was trying to say earlier, is that, if you want two of something, make it in an ipt, then make a new iam and insert two of the items into it. As far as copying features of a solid within an ipt, you can use a variety of methods......project geometry, copy sketches, etc... Good luck Quote Link to comment Share on other sites More sharing options...
mattador04 Posted January 6, 2014 Share Posted January 6, 2014 Like i said, Inventor takes alot of getting used to if you are coming from AutoCAD. It behaves very differently. At first it seems frustrating and illogical, but if you practice, it will make sense. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted January 6, 2014 Share Posted January 6, 2014 Attach your ipt file here and explain why you are trying to copy (it can very easily be done, but might not be the best Inventor way). Have you gone through all the tutorials? Quote Link to comment Share on other sites More sharing options...
gort ben Posted January 6, 2014 Author Share Posted January 6, 2014 Yes I have gone through the tutorials, and done more searching and you're right , inventor is completely different, I am still in the autocad mode. So I guess keep practicing as I have been adviced that as a furniture designer Inventor is the better option. A lot of my designs and concepts are pure geometry and cad has given me new ideas I wouldn't have come with otherwise which is why I am keen to pursue this. Thanks for the advice and check out my website http://www.bengabriel.com. Quote Link to comment Share on other sites More sharing options...
HCb Posted January 7, 2014 Share Posted January 7, 2014 Gort ben, I'm no expert. Not by a long shot. But... I've been using AutoCAD for a little over 2 years, learning it, doing personal design stuff and it was a big paradigm shift from what I was doing in CorelDraw (trying to do technical drawings) but it was worth the headaches learning it. But...I wanted to do more so I started messing with Inventor. Again, a big paradigm shift. The book along with its examples, Mastering Inventor 2012, have been helpful. You can read through a thread I started here, http://www.cadtutor.net/forum/showthread.php?83461-Seemingly-simple-constraints-in-an-assembly-being-impossible-to-implement and see where I started trying to use AutoCAD as my foundation for a design and how JD showed me a simpler way to get the job done which actually worked (my AutoCAD ways didn't work worth a flip in Inventor). JD has been a great help and very pleasant. Give him the files he asks for. Get a 3D mouse. I got a Connexion 3D SpaceNavigator (about 90 bucks on Amazon after sales tax (argh)). Very helpful. It's been a lot of frustrating hours learning the program but, as I go along, I get better and it gets easier, and I can draw things one time and plan my designs faster and easier than I could in 2D. I think the effort is worth it. But it is a huge (to me) paradigm shift from my 2D drawings in AutoCAD. FWIW. --HC Quote Link to comment Share on other sites More sharing options...
gort ben Posted January 7, 2014 Author Share Posted January 7, 2014 Thanks for that, I'll soldier on. Quote Link to comment Share on other sites More sharing options...
gort ben Posted January 8, 2014 Author Share Posted January 8, 2014 Hi me again, learning a lot and a lot to learn. I'm trying to do a sketch in assembly and don't seem to be able to snap on to existing objects which are half visible. And the color tab on the quick access bar shows nothing not sure whether that is the software, any ideas appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
JD Mather Posted January 8, 2014 Share Posted January 8, 2014 ... snap on to existing objects Project Geometry which are half visible. Tools>Application Options>Assembly tab controls this (Opacity of active or all parts) but I recommend you leave it on default. Quote Link to comment Share on other sites More sharing options...
gort ben Posted January 9, 2014 Author Share Posted January 9, 2014 Thanks for that tip JD, and I've since discovered that the new styles file is missing on the program and found it on the computer local disc but can't get it to work in the program, excuse my ignorance and appreciate any pointers. Thanks. Quote Link to comment Share on other sites More sharing options...
