Annotative Block With Dynamic Properties - Rotation Issues at Annotative Scales
nwinslow
I created the attached block to add spot elevations to a drawing. The block has attributes allowing elevations to be manually typed in, but also includes many dynamic features for rotation, lengthening, mirroring, etc. The block was created as an annotative block.
The block and all of its features work perfect as long as the dynamic features (rotation, etc) are not used after additional annotative scales are added. I often times have a drawing set at 1:10 or 1:20 scale and need to do an enlarged detail at 1:5.
What I would like to do is have this block set at 1:10 scale and 1:5 scale and manually rotate it (ideally using the dynamic features) at different angles for each scale. Is this possible and if so, why is it not working with this block? This works flawlessly when using annotative multileaders, so why shouldn't it work with blocks or is this just too labor intensive for the software?
I have also tried attsync, etc. and often times when rotating at different annotative scales, the text attributes go "bonkers" for the opposing scale when applying attsync.
Any help would be greatly appreciated.
Proposed Spot Elevation.dwg
  • 1 year later...
Granted this was posted a while ago (poor person didn't get a very nice welcome did he) but i am having similar problems with rotation at different annotative scales, anybody !!
Edited by KiLLiNG-TiME
  • 2 weeks later...
Not possible with a flip action and a multiline attribute. Change your ELEV2 attribute to a single line and your problem is solved.
You can use a block properties table though.
  • 5 years later...
Hi Iconeo,
Been a while since your post, but that column tag is awesome the way it automatically flips, very classy.  Can you share?
C
Edited by charliecad
better
On 21/11/2020 at 01:59, iconeo said:
Glad you got some use out of it!
I've had a go at my application of this tool using your instructions, attached, but it is not working
Can you have a look and advise?
Just email directly if easier
charlie@charliehewitt.com.au
Happy to pay for your time
Regards
C
Section3.dwg
  • 3 weeks later...
Are you just trying to keep the text so that it is readable? Try changing the angle of the block properties so that it inverts as you rotate it. You will need to apply the same rotational effect to the other text bubble as well.
Edited by iconeo
