Sparky Posted January 9, 2014 Share Posted January 9, 2014 I'm having trouble with the spacing of my text when I import a .rtf file. The spaces change width based on the width of the columns. The problem does not effect all the paragraphs only select ones. If I change the width of the column the spacing of the text will fix itself. All of the text is the same text style. I have attached a copy for reference. Thanks for your help! Specifications-CADTutor.dwg Quote Link to comment Share on other sites More sharing options...
Spaj Posted January 9, 2014 Share Posted January 9, 2014 Hi Not sure if this is the problem, but check you're justification, it seems to be set on centralize, rather than left justify. Quote Link to comment Share on other sites More sharing options...
Sparky Posted January 9, 2014 Author Share Posted January 9, 2014 No, that was the problem. Just a silly oversight on my part! I didn't think to recheck the justification after importing. Thanks! Quote Link to comment Share on other sites More sharing options...
