Results 1 to 4 of 4
    Senior Member
    vertical horizons's Computer Details
    Windows 8 PRO
    DX79TO
    I-7 3820 @3.60 GHz
    16.0 GB
    AMD FirePro W7000
    16 GB
    ViewSonic VX2739wm (Primary) & HP w1907 (Secondary)
    Manufacture
    vertical horizons's Discipline Details
    Drafting Supervisor
    Manufacture
    not applicable
    Mar 2010
    Texas
    236
    Default Sheet Metal Cylinder - "Creating" & "Flatten" Question
    I need to create a cylinder that is 30"Ø, 36.00" tall, with a wall thickness of 0.25".
    I don't see where to set the wall thickness.
    Here is the procedure I followed:
    • Start a new part;
    • Go to SHEET METAL > BASE FLANGE/TAB;
    • Select the Top Plane;
    • Select CIRCLE;
    • Create a circle that is 30.00"Ø,
    • Exit SKETCH;
    • For Sheet Metal Parameters, I enter 36.00" to make the cylinder height 36.00";
    This is where I get confused.
    I do not know what the K-Factor & the Auto Relief are, or what they do.
    I do not see where I would specify that the wall thickness should be 0.25".
    Am I supposed to specify the wall thickness on this page, or is there another place to place that dimension?
    Once this cylinder is created, I also need to be able to unfold (or flatten) it.
    Is there a better way to create this cylinder, that will allow me to FLATTEN it?
    Senior Member
    Windows 8 PRO
    DX79TO
    I-7 3820 @3.60 GHz
    16.0 GB
    AMD FirePro W7000
    16 GB
    Manufacture
    Drafting Supervisor
    Manufacture
    not applicable
    Mar 2010
    Texas
    236
    I found a way to create the cylinder, but I don't know if this is the correct way to do it.
    I sketched a circle that was 30.00"Ø.
    Then, I trimmed out 1/8" out of the circumference of the circle, so that, now the circle was not a complete circle.
    I then went to SHEET METAL, and created the 36" tall cylinder, with a 0.25" wall thickness.
    The cylinder will now FLATTEN, and UNFLATTEN.
    I just have to remember that when I need to know the length of the cylinder, when it's flattened, I have to ADD the 1/8" that I originally removed from the circle.
    This is the end result.
    If this is NOT the correct method, someone please let me know.
    Last edited by vertical horizons; 9th Jan 2014 at 10:46 pm. Reason: Adding Images For Clarity
    Senior Member
    Windows 8 PRO
    DX79TO
    I-7 3820 @3.60 GHz
    16.0 GB
    AMD FirePro W7000
    16 GB
    Manufacture
    Drafting Supervisor
    Manufacture
    not applicable
    Mar 2010
    Texas
    236
    Actually, I was just informed that, when they construct a cylinder, they will roll the steel to where the 2 ends almost meet, leaving the 2 ends 1/8" apart from each other, to allow for welding. So, I guess, until someone shows me a better way to create a cylinder, this way will have to do.
    Super Member stevsmith's Avatar
    stevsmith's Computer Details
    Windows 7 (64bit)
    Mechanical
    stevsmith's Discipline Details
    High Plains Drifter
    Mechanical
    Solidworks 2015
    Apr 2008
    Largs, Scotland
    1,072
    Hi Vert,
    Unfortunately, this is the correct way to do a rolled cylinder in Solidworks (e.g. creating a circle and breaking it at a point.
    The exact K-Factor is dependent to your Brake Press tooling and forming methods. It may vary from company to company and machine manufacturer. I'll try and give the layman's terms.
    K-Factor is the expression given to the to point in the thickness of the material where there is no-compression. the k-factor itself relates to a percentage of the thickness of the material:
    e.g. 44% = 0.44, 50% = 0.50 etc.etc
    This percentage is taken from the inside radii when formed.
    Generally material under 3mm has a k-factor of 0.44 but then again this depends on the material used (alloy, M/S or St/St)
    http://sheetmetal.me/k-factor/
    http://designandmotion.net/design-2/...etal-k-factor/
    "The fear of death follows from the fear of life. A man who lives fully is prepared to die at any time"
    SolidWorks | AutoCAD | Creo
  1. Replies: 21
    Last Post: 14th Jul 2014, 07:04 am
  2. Replies: 5
    Last Post: 19th Sep 2013, 03:27 pm
  3. Interface question - hiding the "_", box, and "X" controls in model tab?
    By jjatho in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 16th Nov 2012, 08:28 pm
  4. Replies: 1
    Last Post: 25th Nov 2009, 06:35 pm
  5. Sheet metal - "un-bend"
    By sloman in forum AutoCAD Beginners' Area
    Last Post: 30th Dec 2007, 03:36 am
