minhphuong_humg Posted January 12, 2014 Share Posted January 12, 2014 Hello, I have a some problem hope everybody help me. With the help of Super Member steven-g and of myself trying, I finished drawing with Dynamic blocks and Attribute blocks. Now I have a lisp to export to excel (2010) as the table attached drawings. Please help me write a lisp to do it! Thank you very much. File image: http://www.mediafire.com/view/bolzs7ao800xgdc/original.png File cad: http://www.mediafire.com/download/2gr184zwr1qk1c1/Dynamic%20Block%20Full.dwg File excel: http://www.mediafire.com/view/epag21ja65775ol/Dynamic.xls Quote Link to comment Share on other sites More sharing options...
WPerciful Posted January 13, 2014 Share Posted January 13, 2014 When you run the routine did you want to select each block, or did you want the routine to select blocks for you? If you want the routine to select the blocks for you and then get their attribute value, what is the block name/s? Quote Link to comment Share on other sites More sharing options...
minhphuong_humg Posted January 13, 2014 Author Share Posted January 13, 2014 When you run the routine did you want to select each block, or did you want the routine to select blocks for you?If you want the routine to select the blocks for you and then get their attribute value, what is the block name/s? Dir WPerciful, The block name is DimPC (Dynamic blocks) and Buble (Attribute blocks). Please, help me. Thank you very much. Quote Link to comment Share on other sites More sharing options...
WPerciful Posted January 13, 2014 Share Posted January 13, 2014 So you want a routine that will get the attribute values for all "DimPC" and "Buble" blocks in a file then export those values to an excel file? Quote Link to comment Share on other sites More sharing options...
minhphuong_humg Posted January 13, 2014 Author Share Posted January 13, 2014 So you want a routine that will get the attribute values for all "DimPC" and "Buble" blocks in a file then export those values to an excel file? Dir Wperciful, I mean exactly that. Please, help me write a lisp extract data to the same file excel attach. Thank you. Quote Link to comment Share on other sites More sharing options...
marko_ribar Posted January 13, 2014 Share Posted January 13, 2014 Please, look this solution here : http://www.theswamp.org/index.php?topic=46057.msg511617#msg511617 M.R. Quote Link to comment Share on other sites More sharing options...
