Problem after import from CATIA to Autocad
Skyuro
hello, i have a problem. First i did a model in CATIA after that i import it to AUtocad. Everything was ok with model but in zoom in model are discontinuities. BxPBxZ
Maybe if you attach a copy of the drawing to your next post we can get a better idea about the problem(s) you are facing.
When you brought the model into AutoCAD what form did it take? Is it a mesh, a surface or a solid?
Ok, so you imported a STEP file and you say you ended up with a solid. I still don't have a clear picture of where these inconsistencies are being encountered. A DWG file would be helpful. If not that how about an image (a closeup)?
