Matchrop viewport
vnanhvu
Hi all.
You can know command which as " Matchrop " Viewport Frame 1 to Viewport Fame 2 but viewport scale no change Layer frozen. ( Ex: I use Command LAYFRZ to frozen layer 1, layer 2, layer 3 in Viewport 1 ( Viewport 1 with Viewport Scale 1/100. I creat a viewport 2 with Viewport Scale 1/200. I want Viewport 2 setting Frozen layers same Viewport 1 but no change Viewport Sacle 1/200 ).
Any idea ? :(....Thank you !
You can get the current layer settings of a viewport and then apply them to another just using the layer command and saving them as a layer state. Dit it recently worked well, just use the layer state option 3rd form left in the layers command.
How do you get the current layers setting of a viewport ?? And can get as command MATCHROP...Thank you !
  • 1 year later...
Nice question vnanhvu. Sometimes the answer is closer than we think.
Lock your viewport first, then make your match properties. You will obtain the same layer setup, and it wont affect your scale.
Cheers
