for knowing layouts to .dwgs and .dwgs to layouts
121madhu
Hi every one
Any one please help me how to export/import layouts to .dwg. (.dwg s to layouts)
Check this img to understand my question I have one .dwg there is multiple layouts each layout export to .dwg
Actual .dwg name: - SUD1-01-002-MOU-TS8-1-WAT-DRW-0000 and layouts (0100), (0101), (0102), (0103), etc…
After export result of .dwg:-
SUD1-01-002-MOU-TS8-1-WAT-DRW-0100
SUD1-01-002-MOU-TS8-1-WAT-DRW-0101
SUD1-01-002-MOU-TS8-1-WAT-DRW-0102
SUD1-01-002-MOU-TS8-1-WAT-DRW-0103
SUD1-01-002-MOU-TS8-1-WAT-DRW-0104
SUD1-01-002-MOU-TS8-1-WAT-DRW-0105
And the same way I have multiple .dwgs all .dwg model space is same but layout deferent (0100), (0101), (0102), (0103), etc…
So I need all .dwg to single dwg
yes i am looking this thank you
and another one is opposite way multiple dwgs to single dwg(multiple layouts)
dwgstolayouts
there is no way to create manually(for learning)
thank you ReMark.
another question
how model space rectangles then generate layouts
i made tittle block so i need every model space rectangles to generate layouts and put my tittle and page settup its possible please explain me are suggest refrense site address or .pdf
tittle block another .dwg
add to current dwg.
model space i divide 23 parts (rectangles) to print scale 1:1
so i need 23 layouts and all layouts also put my tittle block like .external ref or block
I don't know how you would generate a layout for each of your rectangles and add a title block to it via lisp. Your method of setting up a drawing leaves me puzzled.
this method useful to me please any suggestions to doing like this rectangles to layouts
lisp routine also no problem
thank you
(sorry for my bad English)
I'm confused too. Are you trying to show sections at a time cause you want a bigger scale for your layout and the whole drawing won't fit? I've never used a command that could create layouts based on the geometry of the drawing but I'm sure somebody might know of someway of doing that. If that's what you want to do?
