Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
    Forum Newbie
    AutoCAD 2013
    Jan 2014
    Toronto, Canada
    9
    Default How to generate 3-view Orhtographic from 3D Model
    I have a finished 3D model in AutoCAD (although I did import it from another program), and I want to create the standard orthographic views as easily as possible. This tutorial looked perfect http://www.dummies.com/how-to/conten...n-autocad.html but i ran into some trouble. At step 5, where it says to press Base or use the command VIEWBASE i get a window that will ask me to open up some kind of inventor file. The tutorial does not acknowledge this, but the rest of the instructions and result seem like just what I need!
    Anybody know how to do it in this way or in some other easy way?
    Any help is appreciated considering I need this as part of my project pretty soon. Please try and be clear and beginner friendly with instructions, I am only a student and have only been using AutoCAD for two years.
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Welcome to Cadtutor
    Personally, I still prefer FLATSHOT for generating 2D documentation, but since you asked for "as easily as possible"...
    Assuming the imported model is compatible, VIEWBASE should have options to create the view "From Model Space" or "From Inventor"
    Full Member
    Marvin7's Computer Details
    Win7 64-bit
    Dell M6600 laptop
    i7-2640M @2.80 GHz
    6 GB DDR3
    Firepro M8900 Mobility Pro
    750GB
    laptop screen + 22" extra monitor
    Mechanical
    Marvin7's Discipline Details
    Mechanical Drafter
    Mechanical
    Design and fabricate large, industrial heat exchangers (coolers).
    Mechanical 2013
    Feb 2013
    Tulsa, OK
    98
    If you use VIEWBASE like Nestly showed, you might want to turn off "Auto Update" in the contextual ribbon. Occasionally, in AutoCAD 2013, when you change the geometry after the fact, AutoCAD's base views will crap out (the view will disappear) unpredictably. With "Auto Update" off, at least you'll know when a view has gone bad...because you were the one who initiated the update, allowing you to undo the updated view if you want to.
    Forum Newbie
    AutoCAD 2013
    Jan 2014
    Toronto, Canada
    9
    WTC Ortho.dwg
    I saw the the two options that you mentioned, and I originally did choose 'From Model Space', but for some reason, it kept opening the inventor window as if I kept choosing the other option. I double checked it just now, and indeed I am not going insane. So, am I looking at a re-install as a possible solution?
    Anyways I have attached my file, if anyone could see if there is something wrong with it but i doubt its that.
  5. #5
    Forum Newbie
    AutoCAD 2013
    Jan 2014
    Toronto, Canada
    9
    I guess learning FLATSHOT should be easier than figuring out why I cant press 'From Model Space' properly. If nothing else, I'll give it a try, thank you.
  6. #6
    Forum Deity
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    I don't think there's a problem with your AutoCAD, I believe the issue is that the model is constructed of polymesh faces... objects that neither VIEWBASE nor FLATSHOT can project. I don't work with polymesh faces, I'm not sure what your options are?
  7. #7
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,739
    Very interesting concept. Not that I fully understand it in its entirety but I see lots of potential. Anyway, my idea would be to trace over as much of your original design using closed polylines or 3Dpolylines and reproduce the model as a solid. Something similar to what is shown below. Each color represents a different layer.
    I wasn't quite sure what you were attempting to do at the back of the structure so I did not proceed any further. If you care to explain it to me I'd make the necessary additions then upload/attach a copy of the drawing if you were interested. If not, that's OK. No offense will be taken. I'll just consign the file to the recycle bin.
  8. #8
    Forum Deity
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Maybe try Mesh to Solid lisp, or the free Polyhedral Mesh to Solid plugin for AutoCAD at the Autodesk App Store? (disclaimer: I haven't test either)
    *edit M2S.lsp doesn't do what's needed in this case, however FLATSHOT does work after simply converting the Polyface Meshes to Meshes using MESHSMOOTH command.
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,739
    Karuga: Does this work for you?
  10. #10
    Forum Newbie
    AutoCAD 2013
    Jan 2014
    Toronto, Canada
    9
    Wow that looks amazing! Because I have never done anything 3D in AutoCAD before (I normally play with baby toys like SketchUp, shame I know), I must admit I have hardly any idea what you are talking about with the 3D poly-lines and meshes.
    How did you come to this final ortho? The remaining hiccup is that I will have to delete lines that wouldn't be visible (they are behind other faces) and replace them with dotted lines, but my poor 3D AutoCAD skills aren't about to let me do that. Are the faces in this ortho just the original 3D model rotated and lined up? Or are they 2D drawings now? If they are 2D could you please describe the process so I can try and learn it?
    Meanwhile, I will try nestly's advice, though I must admit I don't completely understand it either.
    Thanks for dealing with this complete incompetent! You guys are the best.
  1. Generate plan/elevation view - drawings in Autocad Structural Detailing
    By kristopuleshi in forum Vertical Products: General
    Last Post: 16th Jan 2013, 04:08 pm
  2. Replies: 2
    Last Post: 28th Aug 2012, 09:49 am
  3. Can visual styles work like model view, but in plan view?
    By Cad Monkey 2 in forum Architecture & ADT
    Last Post: 16th Jun 2011, 02:03 am
  4. Replies: 9
    Last Post: 15th Jul 2010, 03:15 am
  5. Replies: 6
    Last Post: 13th Aug 2009, 03:59 am
Tags for this Thread
