Results 1 to 7 of 7
    Forum Newbie
    not specified
    Aug 2006
    2
    Default using letters in dimention
    Hi,
    Interested in using letters instead of numbers in dimentions.
    Its purpose it to show, dia is d1 and that dia is d2 and that length is l3 etc.
    is it possible? i guess it is, But how?
    Thanks
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Asus VG248 24" Widescreen & Cintiq 21ux
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,315
    Place your dimension and then click on it to select it. Once it's highlighted, right click and select Properties to open the properties palette. In the Text section there is an option of Text Override. You can change the dimension text to whatever you want.
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
    Forum Newbie
    not specified
    Aug 2006
    2
    Default YOU rock problem solved
    YOU ROCK DUDE.
    Awesome
    Thanks a bunch..... YOU made my Day.
    I am good with matlab and simulink, need anything there let me know,
    Thanks
    Senior Member craigp's Avatar
    AutoCAD 2007
    Jun 2005
    North Lincs, England
    346
    Quote Originally Posted by Cad64
    Thanks! I was wondering about this too, i used to explode the dimension and change the text that way
  5. #5
    Super Member yedan's Avatar
    AutoCAD 2008
    Jul 2006
    Uk, Suffolk
    508
    the problem with overriding dimensions is that they loose their association and no longer update should you stretch your drawing to a different size, they remain at the value you typed instead of updating to the new size. in some cases this not a problem but it can cause trouble if you forget and alter you size without altering you dim.
  6. #6
    Senior Member
    Architectural DT not applicable
    Oct 2005
    is everything
    448
    "ED" then click the dimension gets you into the string's mtext screen faster. As long as "<>" is there you'll get a dim that updates during stretches, and you casn add whatever you want. I.e. "d<>", and the "d" will always be a prefix to the correct dimension.
    In our office everything is color by layer. Including the dim text, which appears as red on the screen. While it may be conceptually correct to never fudge dimensions, sometimes you have to.
    All of our colors plot as black except the grey tones and two colors, one red, one green. We never use those colors for any real layers. When we have a dimension that is lying, we make it color 100, the green color. It jumps out at you that it's a lie. All of our text is supposed to appear as red. So if we have a note that is unresolved we change it to color 100.
    You can zoom out and all the green text jumps at you as something you need to review or at least be aware of.
    It plots like that as well so you can see the conflicts/issues on the paper as well
  7. #7
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,315
    Don't get me wrong, I agree that you should not override dimensions, but I believe that the OP wanted to create a schedule and reference the schedule from the dimension, rather than create 25 drawings of the same widget with 25 sets of different dimensions. A perfect example would be a simple washer. It has an O.D. and an I.D. The O.D. would be overridden as D1 and the I.D. would be overridden as D2. You would then check the schedule to get the dimensions for washer A-1 or B-2 or whatever. This is a pretty common practice.
    Hey Galingula, there's a Bert hater bashing your avatar in the Feedback section. They think it's gross.
    Facebook:
