dsibbo Posted January 17, 2014 Share Posted January 17, 2014 Can anyone help me with this problem. First I click in my viewport and select a few objects (lines/blocks etc) then whenever I type Pan or hold down my center mouse button to Pan. The Command line says the Viewport is viewlocked switching to paper space. Now by switching to paper space everything I selected has now unselected. This basically leaves me the option to select what I see on the screen at one time and can't pan along and select anything else which is unbelievably frustrating on large drawings. Quote Link to comment Share on other sites More sharing options...
Tiger Posted January 17, 2014 Share Posted January 17, 2014 If you use the center mouse button to pan, don't you get a line that says "Switching back to Model Space" when you release the button? Quote Link to comment Share on other sites More sharing options...
steven-g Posted January 17, 2014 Share Posted January 17, 2014 Try vpmax which will let you pan around and select items etc. in model space, then vpmin when you are done to get back to paperspace, there is also an icon at the bottom edge of the screen to control this. Quote Link to comment Share on other sites More sharing options...
dsibbo Posted January 17, 2014 Author Share Posted January 17, 2014 Yes thats what I get and everything deselects Quote Link to comment Share on other sites More sharing options...
Tiger Posted January 17, 2014 Share Posted January 17, 2014 hm. It shouldn't deselect, it doesn't do it for me. I can select stuff, pan in the locked Viewport, and then add other stuff. What do you have the variable PICKADD set to? Quote Link to comment Share on other sites More sharing options...
dsibbo Posted January 17, 2014 Author Share Posted January 17, 2014 its set to 2 Quote Link to comment Share on other sites More sharing options...
Tiger Posted January 17, 2014 Share Posted January 17, 2014 Does it do the same in a brand new DWG? You shouldn't need to manually switch back to Paper Space after you have Panned. You are in the same Viewport all the time right? Quote Link to comment Share on other sites More sharing options...
MSasu Posted January 17, 2014 Share Posted January 17, 2014 According with this previous discussion it seems to be an AutoCAD bug. Quote Link to comment Share on other sites More sharing options...
dsibbo Posted January 17, 2014 Author Share Posted January 17, 2014 Does it do the same in a brand new DWG? You shouldn't need to manually switch back to Paper Space after you have Panned. You are in the same Viewport all the time right? Yes I click in the viewport and select items then pan and it deselects everything. And while this happens the command line is switching between spaces. It only happens in certain drawings though. Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 17, 2014 Share Posted January 17, 2014 Look at this and make sure to read the reply by VeronicaSmith58. http://forums.autodesk.com/t5/AutoCAD-2013-2014-DWG-Format/Deselect-in-viewports-when-panning/td-p/3618380/page/2 Quote Link to comment Share on other sites More sharing options...
dsibbo Posted January 17, 2014 Author Share Posted January 17, 2014 Look at this and make sure to read the reply by VeronicaSmith58. http://forums.autodesk.com/t5/AutoCAD-2013-2014-DWG-Format/Deselect-in-viewports-when-panning/td-p/3618380/page/2 Thanks ReMark. Would you happen to know how I apply Pan Realtime to my center mouseclick rather than normal Pan? Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 17, 2014 Share Posted January 17, 2014 I suppose you would have to edit your CUIx. Quote Link to comment Share on other sites More sharing options...
