Results 1 to 2 of 2
    Full Member
    Ravenstown's Computer Details
    Windows 7 Professional
    HP Pavilion Elite HPE
    AMP Phenom II x6 1045T 2.7GHz
    16GB
    NVIDIA GeForce GTX 680
    Toshiba 32" LCD
    Electrical
    MEP 2013
    Apr 2012
    Baltimore, MD
    41
    Default conduit connectors shown as 'not connected'
    When join two sections of conduit (same size, same connection type, same plane/elevation) I am still getting the yellow triangles with the exclamation point inside, telling me that the 'conduit connector is not connected to another object'.
    This is happening whether the two sections are at different angles to each (but same plane) or they are just a distance away from each other requiring an offset (two elbows)
    The method that I am using is to select one section of conduit pick the plus sign at the end of the segment and move the mouse over the other section at the end I want to connect to. Once the 'connector' symbol appears I click on it.
    This has worked fine for years but occasionally gives me this result.
    Senior Member hertz hound's Avatar
    hertz hound's Computer Details
    windows 7
    Dell precision T1600
    Construction
    hertz hound's Discipline Details
    Electrician
    Construction
    Auto Cad as-built and coordination drawings when needed, otherwise in the field with the tools.
    MEP 2015
    Jan 2012
    USA - New Jersey
    138
    There was a fix to the drawing file for that quirk, but I can't find it. It was not the OP so it is harder for me to find.
    When that happens to me I use the node osnap and that takes care of it. If it gets so bad I copy everything to a new drawing file. Only had to do that once.
  1. are there any 2D cad blocks available for cable connectors/adapters?
    By cbs-cad in forum Blocks, Images, Models & Materials
    Last Post: 26th Sep 2012, 05:06 pm
  2. Move, Reverse, Stretch Connectors
    By ReMark in forum Electrical
    Last Post: 26th May 2010, 04:52 pm
  3. ASSigning conduit connectors...........
    By dumfatnhappy in forum MEP
    Last Post: 22nd May 2010, 04:23 pm
  4. Revit Family Editor - Pipe Connectors
    By Jaxom in forum Revit General
    Last Post: 6th Oct 2009, 06:45 pm
  5. Making Sure Lines Are Truly Connected
    By Shanna in forum AutoCAD General
    Last Post: 24th Oct 2007, 02:21 am
