Macro for scaling object stopped working
martan1912
Hello,
I had 2 custom buttons on my toolbar for scaling certain objects between metric and imperial units, for some reason they don't work in version 2014.
To scale to metric I have this macro:
select;\scale;$M=$(if,$(=,$(getvar,pickfirst),0),previous;)\25.4
To scale to inches:
select;\scale;$M=$(if,$(=,$(getvar,pickfirst),0),previous;)\0.03937007874015748031496062992126
Does it have to be rewritten ? It used to work just perfect for what I need it for.
Thanks for help.
Edited by SLW210
added code tags.
There is a space between the P and R in "Previous" and there is one more space after the semi colon behind the word "Previous".
I know, that's how it got pasted into the message window, I don't know why, but it is typed in correctly in Autocad. As I mentioned, it worked just fine in other versions.
Honestly I haven't made them, I got them somewhere while back. If there is a simpler way to achieve the same, I'd appreciate your help. I just need this tool since I do a lot of CNC work and I have to use metric objects in my CAD, also going back and forth between units. It really helps with everyday work.
^C^Cscale;\;\25.4;
That is to go from standard to metric. To make it go from metric to standard just change the number at the end. I can adjust it a bit to fit your needs if you would like. Just let me know if you need me to add anything. :)
If you add one more \ like so:
^C^Cscale;\\;\25.4;
You can window objects... OR if you want to scale everything then this:
^C^Cscale;all;\25.4;
Would be better.
Thanks for your offer to help. Now , is this going to let me pick objects I want to scale first ? That's how it used to work. Click on the icon, select the objects and they got scaled.
I don't want to scale all objects in the drawing, just some of them, per my selection.
