Results 1 to 4 of 4
    Forum Newbie
    AutoCAD LT 2013
    Nov 2013
    2
    Default Removing all objects not on current page layout AutoCad LT 2013 and LT 2014
    Hello, I work for a practice of landscape architects. On the project I'm working on we have a series of drawings covering the site layout or construction details. Each drawing will issue corresponds to a page layout. When we issue revised drawings to the contractor as PDFs we also need to issue DWGs to the other members of the design team.
    I bind any xrefs and remove all unrelated page layouts... however, the DWG is still very large and most importantly the model space still contains a lot of extra, unnecessary information. It's just not cost effective to manually strip away objects that won't be visible in the page layout.
    Is there a way to delete all objects from layers that are frozen or not visible, or all objects that are visible but do not appear within the viewports on the current page layout?
    I already PURGE and -PURGE RegApps to reduce some clutter and reduce file size.
    Oh - I've also tried the Export Layout tool. This frequently crashes with a fatal error and when it does work, the resulting model is in page units and looses it's "position" in the real world.
    We're using both LT 2013 and LT 2014. I think we have access to a version of AutoCad Map 3d 2013.
    Thanks for your time in reading this!
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,158
    You could click into one viewport and try Ctrl+A to select everything, then click into each viewport and deselect everything in the viewport using Shift+ crossing window, you can go into all the viewports without losing the selection set, and deselect all visible items, and then press delete. This will delete everything else including stuff on layers that are 'off', but not frozen layers.
    But I would do a test first on a copy of a drawing.
    Forum Newbie
    AutoCAD LT 2013
    Nov 2013
    2
    Many thanks Steven. That seems to work for a layout with one viewport looking onto the model. I can't seem to get it to work with a layout with multiple viewports. No matter.
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,158
    Once you have deselected objects in one viewport you should be able to just use a single left mouse click over another viewport to make that viewport active without altering the selection set, then, deselect objects again with shift and mouse.
  1. Autocad 2013 page setup/ plot styles
    By arcbc30 in forum AutoCAD Drawing Management & Output
    Last Post: 4th Mar 2014, 02:28 pm
  2. Trim command change between AutoCAD 2013 & 2014
    By Sparky in forum AutoCAD General
    Last Post: 15th Nov 2013, 06:03 pm
  3. Autocad C3D 2013 vs Autocad 2014 Comparison
    By PaddlesUpRiver in forum Civil 3D & LDD
    Last Post: 26th Sep 2013, 06:26 pm
  4. Replies: 5
    Last Post: 25th Apr 2013, 03:47 pm
  5. Are Autocad 2013 and 2014 interchangable?
    By Knz183 in forum AutoCAD Beginners' Area
    Last Post: 6th Apr 2013, 08:46 pm
Tags for this Thread
