Results 1 to 8 of 8
    Full Member
    TheyCallMeJohn's Computer Details
    Windows 7
    Dell Precision M6800
    Intel Core i7-4930MX @ 3.00 GHz
    32.0 GB
    NVIDIA Quadro FX 5800
    AutoCAD 2015
    Apr 2010
    Huntington Beach, CA
    80
    Default Append 3D Points to a List
    I have tried several combination and gone thru about a 100 posts but I can't figure out what I am doing wrong.
    I am filtering thru objects and pulling out a 3D coordinate from the database. Then I am turning that into a 3 point list (x y z). Then I want to create a list of those points and add to them to the existing list as the program filters thru the remaining objects from the selection set.
    Code:
    	(setq unitpoint_orig (vl-string-right-trim ";" (substr (vlax-get entvla 'points) 12)))
    	(if (and(or (= Z_pref "Y")(= Z_pref "y"))(/= Z_height nil))
    			(setq unitpoint_mod (comma_pull unitpoint_orig "REAL_NUM"))
    			(setq unitpoint (list (car unitpoint_mod) (cadr unitpoint_mod) (caddr Z_height)))
    		(setq unitpoint (comma_pull unitpoint_orig "REAL_NUM"))
    	(setq unitpoint_lst (append unitpoint_lst 'unitpoint))
    	;(command "insert" pl_block unitpoint "1" "1" "0")
    Current Result: (105.13 3165.22 0.0 105.13 3194.65 0.0 105.13 3142.5 0.0)
    Desired Result: ((105.13 3165.22 0.0)(105.13 3194.65 0.0)(105.13 3142.5 0.0))
    Once I get this part working, I am then planning on filtering for duplicates using Lee Mac's subroutines. Then inserting based off those points.
    Senior Member ymg3's Avatar
    not applicable
    May 2011
    414
    TheyCallMeJohn.
    You could use this small routine on your list.
    Code:
    (defun tupl3 (l) (if l (cons (list (car l) (cadr l) (caddr l))(tupl3 (cdddr l)))))
    So for example:
    Code:
    (tupl3 '(105.13 3165.22 0.0 105.13 3194.65 0.0 105.13 3142.5 0.0))
    ((105.13 3165.22 0.0) (105.13 3194.65 0.0) (105.13 3142.5 0.0))
    _$
    or change
    Code:
    to
    (setq unitpoint_lst (append unitpoint_lst (list unitpoint)))
    Full Member
    Windows 7
    32.0 GB
    AutoCAD 2015
    Apr 2010
    80
    Default Just what I needed...
    Exactly what I needed... ( I swear I tired the same thing with " ' " instead of "list" but I guess I made a mistake,
    Quote Originally Posted by ymg3 View Post
    TheyCallMeJohn.
    Code:
    to
    Forum Deity David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    2,547
    Not a big deal with small lists, but ( cons ) is a ton faster than ( append ).
    You basically (cons pt list) and then if the order of the list is important (reverse lst)
    If you work with say 30,000 atoms, it can make a significant difference. -David
    -David
    R12 (Dos) - A2K
  5. #5
    not applicable
    May 2011
    414
    TheyCallMeJohn,
    David is exactly right, I tend to stay away from append.
    In your case you could simply :
    Code:
    (setq unitpoint_lst (cons unitpoint unitpoint_lst))
    ; and if necessary at the end :
    (setq unitpoint_lst (reverse unitpoint_lst))
    Also ,not entirely necessary but, I usually set the list
    to nil before starting to build it. It is specially
    useful in the debugging phase where very often
    you have not declared your variables and are
    running test.
    ymg
  6. #6
    Full Member
    Windows 7
    32.0 GB
    AutoCAD 2015
    Apr 2010
    80
    Question
    TheyCallMeJohn,
    Code:
    running test.
    ymg
    David and Ymg,
    Thanks for the suggestion. I will try out cons and see if that works. Also I do set it to nil, I just put it right under the defun so when I am done it easier to make the necessary variables local once I debug the code.
    UPDATE:
    So it tried substituting this:
    Code:
    (setq unitpoint_lst (cons unitpoint_lst (list unitpoint)))
    for this:
    Code:
    And it didn't work, is there something else I need to change?
  7. #7
    not applicable
    May 2011
    414
    TheyCallMeJohn,
    Here is a small example making use of Gilles Chanteau's parsing routine.
    I have setup a dummy list of string to parse:
    Code:
    (defun test ()
       (setq datalist '(";;;1.0, 2.0, 3.0,       weerertttretqrt"  ";;;4.0, 5.0, 6.0,       weerertttretqrt"    ";;;7.0, 8.0,9.0,       weerertttretqrt"))
       (setq parsedlist nil)
       (foreach item datalist
           (setq parsedlist (cons (str2lst (vl-string-left-trim ";" item) ",") parsedlist))
       (setq coordlist nil)
       (foreach str parsedlist
           (setq coordlist (cons (list (atof (car str)) (atof (cadr str)) (atof (caddr str))) coordlist))
    ;; str2lst     by Gilles Chanteau                                             ;
    ;; Transform a string with separator into a list of strings.                  ;
    ;; Arguments:        ;
    ;; str : string of characters                                                 ;
    ;; sep : separator characters                                                 ;
    (defun str2lst (str sep / len lst)
      (setq len (strlen sep))
      (while (setq pos (vl-string-search sep str))
        (setq lst (cons (substr str 1 pos) lst)
    	  str (substr str (+ len pos 1))
      (reverse (cons (substr str 1 pos) lst))
    Now here are the reult after running:
    Code:
    _$ (test)
    _$ parsedlist
    (("7.0" " 8.0" "9.0" "       weerertttretqrt") ("4.0" " 5.0" " 6.0" "       weerertttretqrt") ("1.0" " 2.0" " 3.0" "       weerertttretqrt"))
    _$ coordlist
    ((1.0 2.0 3.0) (4.0 5.0 6.0) (7.0 8.0 9.0))
    _$
    As you can see as you go through the first foreach loop, your result come out with
    the last item at the first position.
    Now we run another foreach loop to cons the list of coordinates and you end up
    with the list in the correct order.
    So say we did not have to do the second loop, but you still want your list in the proper
    order. You woul issue (reverse list).
    The only reason we are telling you to use cons is that it is faster than append by a factor of ten
    specially on long list. In your case you don't have to, but it is nonetheless something you
    want to know.
    Now if you would post your typical data line as returned by (vlax-get entvla 'points),
    maybe we could come up with suggestion to make your task easier.
    ymg
  8. #8
    not applicable
    May 2011
    414
    TheytCallMeJohnn,
    In answer to post #6 what you need is:
    Code:
    (setq unitpoint_lst (cons unitpoint  unitpoint_list))
    ymg
  1. Creat list of polyline points
    By Lt Dan's legs in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Aug 2010, 05:48 pm
  2. Find the list of the nearest 3 points
    By motee-z in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th Apr 2010, 06:41 am
  3. cons list of points?
    By M76 in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Mar 2010, 03:47 pm
  4. COPY Command and list of points ?
    By chavlji in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Mar 2009, 02:41 pm
  5. create list of points
    By jdurand in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd May 2006, 08:02 am
Tags for this Thread
