+ Reply to Thread
Results 1 to 4 of 4
  1. #1
    Junior Member
    Computer Details
    BarbM's Computer Details
    Operating System:
    Windows 7 64 bit
    Computer:
    HP
    Monitor:
    HP 24"
    Discipline
    Civil
    BarbM's Discipline Details
    Occupation
    Senior Engineering Tech
    Discipline
    Civil
    Details
    I work in the Engineering division of Iowa City's Department of Public Works. I create and maintain city maps, and city infrastructure improvement construction plans.
    Using
    Civil 3D 2014
    Join Date
    Jan 2014
    Location
    Iowa City, Iowa
    Posts
    20
    Default How do I style an assembly?
    Assemblies are built with cross hatching, or shading, built in - can I style (edit) the cross hatch? I'd like to be able to hide/show the hatching, or at the very least change the color to what will print as a half tone. Any tips? I've looked everywhere, but had no luck.
  2. #2
    Senior Member
    Using
    Civil 3D 2011
    Join Date
    Aug 2011
    Posts
    151
    Default
    Those are part of the Shape Style. You can change layer, color, pattern, On\Off.
    To find what shape your assembly uses, go to the assembly properties, under Codes it will list the shapes it uses.
  3. #3
    Junior Member
    Computer Details
    Operating System:
    Windows 7 64 bit
    Computer:
    HP
    Monitor:
    HP 24"
    Discipline
    Civil
    Occupation
    Discipline
    Civil
    Details
    Using
    Civil 3D 2014
    Join Date
    Jan 2014
    Location
    Iowa City, Iowa
    Posts
    20
    Default
    Thank you Bill. I'll look into it and let you know how it goes.
  4. #4
    Junior Member
    Computer Details
    Operating System:
    Windows 7 64 bit
    Computer:
    HP
    Monitor:
    HP 24"
    Discipline
    Civil
    Occupation
    Discipline
    Civil
    Details
    Using
    Civil 3D 2014
    Join Date
    Jan 2014
    Location
    Iowa City, Iowa
    Posts
    20
    Default Got it!
    Got it Bill - thanks! I just didn't dig down deep enough, or make the connection between codes and shapes. Thanks again.
Similar Threads
  1. making a sub assembly part of the main assembly
    By bigben1103 in forum Autodesk Inventor
    Last Post: 5th May 2013, 11:57 am
  2. animate a hinge as sub-assembly in a an assembly
    By alijahed in forum Autodesk Inventor
    Last Post: 26th Mar 2011, 02:42 am
  3. Assembly into another assembly in inventor
    By Irshaad in forum Autodesk Inventor
    Last Post: 21st Apr 2010, 08:26 pm
  4. Replies: 4
    Last Post: 3rd Oct 2009, 05:42 pm
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
