zigmasas Posted January 23, 2014 Share Posted January 23, 2014 Can someone hellp with cam design, i need to design a cam but i know just tracker movement h=10mm transmission angle= 55 degree and how i can change dimensions from inch to mm.... Quote Link to comment Share on other sites More sharing options...
zigmasas Posted January 23, 2014 Author Share Posted January 23, 2014 someone know more a cam design programs? Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 23, 2014 Share Posted January 23, 2014 (edited) Is that an add-on program you are using with AutoCAD? Duh! I missed that this was posted in the AutoCAD Verticals forum. My bad. Edited January 23, 2014 by ReMark Quote Link to comment Share on other sites More sharing options...
zigmasas Posted January 23, 2014 Author Share Posted January 23, 2014 i using a AutoCAD Mechanical 2012 content->cam design and calculation Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 23, 2014 Share Posted January 23, 2014 Could it have anything to do with the template you started with? In plain AutoCAD the default is a template that uses imperial units. The user has to deliberately select a metric template the first time he/she uses the program for it to become the default after that. Type -DWGUNITS at the command line then press the Enter key. What response do you get back? It might be in the form of a number from 1 to 6. Quote Link to comment Share on other sites More sharing options...
zigmasas Posted January 23, 2014 Author Share Posted January 23, 2014 Unknown command "DWGUNITS". Press F1 for help. Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 23, 2014 Share Posted January 23, 2014 You forgot the dash. It is -DWGUNITS. Quote Link to comment Share on other sites More sharing options...
