HollyRae Posted January 23, 2014 Share Posted January 23, 2014 HELP!! I have (2) separate AutoCAD files; (1) topo, which is at 1"=40'-0" scale, and (1) master site plan from the arch, which is at 1"=30'-0" scale; how do i 'merge' the (2) files and adjust the scales so they match? Quote Link to comment Share on other sites More sharing options...
eldon Posted January 23, 2014 Share Posted January 23, 2014 If everybody has been drawing at 1 to 1 (full scale), you should be able to x-ref one into the other without any scaling, because both should be full scale. The scales you mention are output scales for paper plots. Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted January 23, 2014 Share Posted January 23, 2014 FWIW, I agree with eldon. Post back if you need any more help. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted January 23, 2014 Share Posted January 23, 2014 Check the units in each drawing to make sure they are the same. Quote Link to comment Share on other sites More sharing options...
HollyRae Posted January 30, 2014 Author Share Posted January 30, 2014 thanks; I didn't think to check that Quote Link to comment Share on other sites More sharing options...
