Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
    Forum Newbie
    AutoCAD 2013
    Jan 2014
    3
    Angry Is all of my work gone? (Oleson Village Project)
    Hello, CAD-Pros
    I have been working on my (PF Oleson Village) project for the past few evenings and making some good progress. I have been re-reading chapters in the textbook and reviewing previous posts in the forums to aid me in this endeavor. Late last night I zoomed-extents and all my work was gone. I have been saving after every function. What happened? Do I have to restart from the beginning? Ideas?
    Super Member Tuns's Avatar
    Tuns's Computer Details
    Windows 7 (64-bit)
    Intel Core I3-2120
    4.0 GB
    AutoCAD LT 2014
    Jun 2013
    San Antonio, Texas
    784
    Close and re-open it if you saved it.
    Never argue with an idiot. He will drag you down to his level and beat you with experience.
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    Please check for a file with drawing.BAK extension that should be found in the same name as your exercise file (drawing.DWG). Rename it as drawing1.DWG and open it; it should contain the version before last save.
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,955
    Zoom extents then zoom out a little more. Select>All
    Are any grips showing? If so you have something way off in outer space.
  5. #5
    Forum Deity steven-g's Avatar
    steven-g's Computer Details
    Win 7
    Construction
    steven-g's Discipline Details
    Draughtsman
    Construction
    I work in the estimating department of a large building contractor.
    AutoCAD 2018
    May 2013
    An Englishman in Belgium
    2,115
    So long as you haven't closed the drawing then repeatedly clicking on the undo button should get you back, it sounds like you have an object way off in space, so when you zoom extents everything gets really really small. If you have closed the drawing then don't open it again without making a copy of the ****.bak file from the folder you were saving into, copy it somewhere else and then change the file extension to ****.dwg. That should at least give you a working drawing from a previous save point. And if you did close the drawing, after making copies, open the drawing and try pressing Ctrl+A you will probably see some blue marks at the edge of your screen keep zooming in on one of those it will be your drawing objects that you lost, if it is some odd lost line or geometry then delete it and zoom extents again.
  6. #6
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,588
    Use Zoom, Window, 0,0 , 1000,1000 . Do you see some or most of your work? Zoom out some more until you see everything you are expecting. There is an object thrown out way away from your work which throws off zoom extents. Now use erase, all, R, use a crossing window to select everything you want to keep, hit enter. Now try zoom extents again.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  7. #7
    Forum Newbie
    AutoCAD 2013
    Jan 2014
    3
    Nothing worked ... tried all of your ideas. I guess a have to start over.
    Thanks anyway
    BTW ..why would that occur (work disappearing after zoom - extents)? I thought I was doing everything correctly. Guess not
  8. #8
    Win 7
    Construction
    Draughtsman
    Construction
    AutoCAD 2018
    May 2013
    2,115
    Quote Originally Posted by Nocrow View Post
    Thanks anyway
    Kan you post the drawing, here or something like dropbox if it is too big, stuff shouldn't just vanish, it may just be hiding somewhere.
  9. #9
    AutoCAD 2013
    Nov 2011
    5,994
    DON'T START OVER, until we have had a chance to solve your problem.
    Did you use WINDOWS EXPLORER to open your folder and look for another file of the same name, but ending in .bak?
    If you find that you should be okay.
    Both MSASU and steven-g have suggested what you should do when you find the .bak file.
    AUTOCAD won't find the .bak file, use Windows Explorer to find it.
  10. #10
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,104
    If you use the command STATUS, you can see how many entities are in the drawing.
    Is this project the one where a tree has to be inserted? In some other thread, it revealed that the quoted coordinates were about a mile away. When you zoom extents, the screen expands to show this distant object, but because of the magnification required all your linework appears a dot.
  1. need project help for penn foster oleson village
    By Firligic in forum Student Project Questions
    Last Post: 20th Mar 2017, 11:13 pm
  2. Oleson Village
    By waterman1970 in forum Student Project Questions
    Last Post: 2nd Nov 2013, 02:36 pm
  3. Penn Foster Oleson Village Project Check
    By Batman in forum Student Project Questions
    Last Post: 27th May 2012, 02:27 pm
  4. Penn Foster Oleson Village project
    By bracken2 in forum Student Project Questions
    Last Post: 1st Aug 2011, 04:07 pm
  5. another Oleson village question
    By Autocadstudent in forum Student Project Questions
    Last Post: 12th Feb 2011, 09:09 am
