closest vertex to a point an polyline
HARRY-PLOTTER
Build a list of vertexes and distances from said point and sort it ascending; retain first element.
Another:
(defun c:test ()
   (setq a (vlax-ename->vla-object (car (entsel "\nSelect Polyline"))))
   (setq b (vlax-curve-getClosestPointTo a (trans (cadr (grread T)) 1 0)))
   (setq c (vlax-curve-getParamAtPoint a b))
   (or (< (- c (setq c (fix c))) 0.50000000001) (setq c (1+ c)))
   (setq v (vlax-curve-getPointAtParam a c))
   (princ (strcat "\nVertex n. " (itoa (1+ c)) " (" (rtos (car v)) " " (rtos (cadr v)) ")" ))
Another to add a green point at the nearest param .
(defun c:Test (/ s e pr p pt a b)
 ;;    Tharwat 2014. cadtutor        ;;
 (if (and (setq s (entsel)) (eq (cdr (assoc 0 (entget (setq e (car s))))) "LWPOLYLINE"))
   (progn (setq pr (vlax-curve-getparamatpoint (car s) (setq p (vlax-curve-getclosestpointto (car s) (cadr s)))))
          (if (< (distance p (setq a (vlax-curve-getpointatparam (car s) (fix pr))))
                 (distance p (setq b (vlax-curve-getpointatparam (car s) (1+ (fix pr)))))
            (setq pt a)
            (setq pt b)
          (entmakex (list '(0 . "POINT") (cons 10 pt) '(62 . 3)))
   (princ "\n Nothing selected or not a Polyline <!>")
(vl-load-com)
There is no need to convert the object to with vlax-*** functions ;)
The type of the argument for VLAX-CURVE-* functions family is listed in help as
The VLA-object to be measured
so a good programming practice will be to comply, even if entity name is supported. This will ensure a running code if one day Autodesk decide to enforce the rule (it has happened in the past, although I don't recall the function in case).
(defun c:Test ( / s e pr p pt a b ) (vl-load-com)
 ;;    Tharwat 2014. cadtutor - mods by M.R.    ;;
 (if (and (setq s (entsel)) (wcmatch (cdr (assoc 0 (entget (setq e (car s))))) "*POLYLINE"))
          (entmakex (list '(0 . "POINT") (cons 10 a) '(62 . 3)))
          (entmakex (list '(0 . "POINT") (cons 10 b) '(62 . 3)))
