DS-precast Posted January 27, 2014 Share Posted January 27, 2014 (edited) Hello All I have a simple iLogic Rule which converts the Mass (kg) iProperty into a Custom iProperty measured in tonnes, to 2 decimal places. [color=#800080][b]iProperties[/b][/color][color=#000000].[/color][color=#800080][b]Value[/b][/color][color=#000000][b]([/b][/color][color=#008080]"[/color][color=#008080]Custom[/color][color=#008080]"[/color][color=#000000], [/color][color=#008080]"[/color][color=#008080]Weight (T)[/color][color=#008080]"[/color][color=#000000][b])[/b][/color][color=#000000][b]=[/b][/color][color=#800080][b]Round[/b][/color][color=#000000][b]([/b][/color][color=#800080][b]iProperties[/b][/color][color=#000000].[/color][color=#800080][b]Mass[/b][/color][color=#ff0000][b]/[/b][/color][color=#000000][b]1000[/b][/color][color=#000000],[/color][color=#000000][b]2[/b][/color][color=#000000][b])[/b][/color] The problem I have is that the iProperty value seems to remove trailing zeroes, (ie. it will display '0.8' when I require it to display '0.80'. Could anybody please indicate how to overcome this issue? Many thanks Edited January 27, 2014 by DS-precast Quote Link to comment Share on other sites More sharing options...
Bishop Posted January 29, 2014 Share Posted January 29, 2014 I've got a similar iLogic / iProperty setup in my part and assembly templates, but I went at it a slightly different way. I bring iProperties.Mass in as a parameter, mark it for export, and then in the Custom Property Format window I specify how many decimal places I want, and there's checkboxes for leading & trailing zeroes. Here's the code I use: [color=#800080][b]InventorVb[/b][/color][color=#000000].[/color][color=#800080][b]DocumentUpdate[/b][/color][color=#000000][b]()[/b][/color] [color=#800080][b]Parameter[/b][/color][color=#000000][b]([/b][/color][color=#008080]"[/color][color=#008080]partmass[/color][color=#008080]"[/color][color=#000000][b])[/b][/color][color=#000000][b]=[/b][/color][color=#800080][b]iProperties[/b][/color][color=#000000].[/color][color=#800080][b]Mass[/b][/color] [color=#800080][b]InventorVb[/b][/color][color=#000000].[/color][color=#800080][b]DocumentUpdate[/b][/color][color=#000000][b]()[/b][/color] [b] [/b] Quote Link to comment Share on other sites More sharing options...
DS-precast Posted February 2, 2014 Author Share Posted February 2, 2014 Thanks for the reply Bishop. I will try your solution and compare with the way I have done it, to see the merits or otherwise of each approach. Since posting, I found another solution to the problem which I will post here to help others with the same or similar issues. I found that using the vba FORMAT command, along with the ROUND command seems to produce the results I'm looking for. My code now reads : [color=#800080][b]iProperties[/b][/color][color=#000000].[/color][color=#800080][b]Value[/b][/color][color=#000000][b]([/b][/color][color=#008080]"[/color][color=#008080]Custom[/color][color=#008080]"[/color][color=#000000], [/color][color=#008080]"[/color][color=#008080]Weight (T)[/color][color=#008080]"[/color][color=#000000][b])[/b][/color][color=#000000] [/color][color=#000000][b]=[/b][/color][color=#000000] [/color][color=#800080][b]Format[/b][/color][color=#000000][b]([/b][/color][color=#800080][b]Round[/b][/color][color=#000000][b]([/b][/color][color=#800080][b]iProperties[/b][/color][color=#000000].[/color][color=#800080][b]Mass[/b][/color][color=#ff0000][b]/[/b][/color][color=#000000][b]1000[/b][/color][color=#000000],[/color][color=#000000][b]2[/b][/color][color=#000000][b])[/b][/color][color=#000000], [/color][color=#008080]"[/color][color=#008080]0.#0[/color][color=#008080]"[/color][color=#000000][b])[/b][/color] Thanks for the assistance. Quote Link to comment Share on other sites More sharing options...
