Architectural Drawing books
joesymonds
Never posted in this forum before so hopefully someone can help me!
I bought 'The Essential Guide to Technical Product Specification: Engineering Drawing' recently. Its a brilliant book and has been really helpful, however I am struggling to find something similar for Architectural Drawing.
If anyone can recommend anything it would be very much appreciated.
Cheers, Joe
Thanks guys, although i'm not really after a book to learn AutoCad from. Im after a book that teaches drawing standards for architectural work, layer names, abbreviations, symbols, how drawings should be presented etc.
Does the book that you recommend include this? Or is it more of a step by step guide to using the features Autocad.
Also do the standards change much from country to country?
Cheers, Joe
Yes, standards will often vary country to country.
AIA CAD Layer Guidelines...http://www.nyu.edu/sapd/pdf/NYU_Layer_Standard_Binder.pdf
For British Standards you would probably have to consult BS 1192.
Many companies will choose not to follow a national standard when it comes to CAD drawings and instead create their own.
Ah yes, im located in Britain. Ill search a little further into BS 1192, I dont really want to end up buying the British standards book those things are expensive... Just a decent book on BS1192 would be ideal! Thank you for your help.
There really is no substitute for the actual BS1192 standard to my knowledge. Anything else would basically be a synopsis which won't do you any good.
