Annotative Level Triangle Block?
Hey-
I want to create a block that has the level # on top of the little triangle thingy (yes, highly technical terms are in use), that will automatically resize BOTH the size of the text and the size of the triangle depending on which scale I'm in.
At the moment I can figure out how to make the TEXT (aka the #) annotative, but the triangle stays the same size no matter what scale I'm in. Not only that, but then the text doesn't stay consistently next to the triangle symbol when I change scales.
I want a block where BOTH the Text size for the level AND the triangle symbol itself will always be correct, regardless of what scale my viewport is in. Aka, I put a level symbol for +5.72 in the correct position in Model Space. In Paper Space, my 1:50 viewport and my 1:100 viewports are EACH showing the +5.72 triangle level sign, in the correct place, with the triangle and text being the correct size.
Could anyone direct me on how to create said block? :?
Oh, cool... I didn't know that.
I've tried Googling and can't find what I'm looking for exactly, could you direct me to a tutorial that would show me how to make a block like this? (to clarify- i only want to put the block in on the Model Space once, and for it to pop up on all the variously scaled Viewports...)
I mean, I think I could figure this out on my own if someone could explain to me:
I want a triangle that will look the same once printed no matter what scale its viewport is in. I tried making one but when I selected the triangle in Quick Properties it wouldn't let me click Annotative.
ReMark, thank you... I would have thought this was something readily available online... I wouldn't imagine a LISP would be necessary.
Yes, they are readily available if you know where to look. Annotative blocks as well as just plain blocks can be found in numerous places on the Internet. Two that come to mind immediately are....
AUGI...http://www.augi.com/about-augi
CADforum...http://www.cadforum.cz/catalog_en/
Annotative Scaling tutorials.
Size Does Matter: Annotative Scale Feature by Isaac Harper of Cadsoft Consulting. AutoDesk University 2009, course number AU314-1
Annotation Scaling - Making Drawings Smarter with Intelligent Text by David Cohn of PPI Group. AutoDesk University 2008, course number GD135-1P. http://www.dscohn.com/AU/handouts/GD315-1P%20Annotation%20Scaling-DOC.pdf
Automate Annotation Scalingwith Annotative Objects by Ellen Finkelstein. http://www.ellenfinkelstein.com/acadblog/tutorial-automate-annotation/
Making Blocks Annotative by Donnie Gladfelter. http://thecadgeek.com/blog/2007/05/making-blocks-annotative/
Edited by ReMark
