heschr Posted January 29, 2014 Share Posted January 29, 2014 Hello, after reading along for quite some time (and profiting alot), here comes my first post: I needed a routine to create a lot of polylines with all the same starting point. I got tired of always have to move the first point back to the right starting point. Here is my solution, kind of an copy-strech mix. Could this be achieved in a more elegant way? (defun c:cfp ( / i ss plist_o ss_n elist_t plist_t pcount bpoint) (vl-load-com) ;get points of original polyline (setq ss (car(entsel "\nSelect Polyline to copy.")) plist_o (vl-remove-if-not (function (lambda (pt) (= (car pt) 10))) (entget ss) ) ) ;get userinput on how many points should be fixed and basepoint for multiple copies (initget 4) (setq pcount (getint "\nHow many points should be fixed? <1>")) (if (= pcount nil) (setq pcount 1)) (setq bpoint (getpoint "\nSelect basepoint")) (while (not nil) ;perform copy and get the points of the temporal polyline (command "_copy" ss "" bpoint pause) (setq ss_n (entlast) elist_t (entget ss_n) plist_t (vl-remove-if-not (function (lambda (pt) (= (car pt) 10))) (entget ss_n) ) ) ;change the fixed points of the temporal polyline back to the ;original points and draw the final polyline (setq i 0) (repeat pcount (setq elist_t (subst (nth i plist_o) (nth i plist_t) elist_t ) ) (setq i (1+ i)) ) (entmod elist_t) ) ) Quote Link to comment Share on other sites More sharing options...
