AUTOCAD SNAP - Drafting settings like a floating toolbar ?
gashaglava
Hello everyone,
is it possible to make this like a floating toolbar where I can toggle on/off certain snap types ?
i know there is a snap toolbar, but it snaps only once to desired snap type if the OSNAP (F3) ...
i want to be able to toggle on "intersection" for example, draw few lines, and then turn it off ...
i hope that you will understand what i need
thanks in advance, cheers
miroslav
Go into your CUI, Keyboard Shortcuts, Temporary Override Keys, set up keys for intersection, etc.
I use the Function keys and have F7 set for appintersection.
Hold shift and hit the right mouse button while in a command.
I use defuns in autoload we have about 5 for different settings basicly the variable osmode sets the osnaps. Just type the number, you can create your own toolbar if you want pretty easy either use cui or a partial just steal the existing images from the immense autocad ones.
; sets snaps on
(defun C:39 ()(setvar "osmode" 47))
(defun C:99 ()(setvar "osmode" 31743))
(defun C:8 ()(setvar "osmode" )
(defun C:59 ()(setvar "osmode" 15359))
(defun C:9 ()(setvar "osmode" 9))
