BoroCAD Posted January 31, 2014 Share Posted January 31, 2014 Hi, I'm having a strange day, I can't seem to remember anything! I've added the monochrome visual style to a solid part but the model lines can still be seen. I can't remember how to make the lines not visible. Can anyone please help? Cheers. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 3, 2014 Share Posted February 3, 2014 Did you ever get your problem resolved? If not, can you post an image? Quote Link to comment Share on other sites More sharing options...
BoroCAD Posted February 5, 2014 Author Share Posted February 5, 2014 Hi ReMark, I haven't looked at it again so I haven't got a solution yet. If you could help, then that would be great. I want to make the orange lines not visible. Cheers. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted February 5, 2014 Share Posted February 5, 2014 -shademode dispsilh viewres facetres list Attach dwg file here. Quote Link to comment Share on other sites More sharing options...
BoroCAD Posted March 3, 2014 Author Share Posted March 3, 2014 -shademodedispsilh viewres facetres list Attach dwg file here. JD Mather - Sorry for the late reply, I'm been away. Thanks for responding. I've attached a file containing an object to demonstrate the situation. I've played around with the isolines options through the VSEDGES command and it does partly what I want. What I desire, for example, is the orange isolines removed from the top left layout viewport with the edges still shown as black lines. I've think I may need to turn off the isolines and go into the visual display options and find the command / option for showing the edge lines. Is there an easier way? With regards to your message above, I've never really got to grips with the shademode and dispsilh options. If you have any better descriptions / examples of them in practice that would be brilliant. The Autodesk help is good but the explanations aren't always easy to understand when the concepts are new, they could definitely do with visual examples of the different options / situations. Cheers Isolines Appearance - Handle.dwg Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 3, 2014 Share Posted March 3, 2014 Is this what you are trying to do? Quote Link to comment Share on other sites More sharing options...
BoroCAD Posted March 3, 2014 Author Share Posted March 3, 2014 Remark - Wow, quick response, thanks. Top left looks like what I wanted. How did you do that? I'm assuming I can show the same appearance in the right hand viewport as well. Just so I can learn more. Bottom left - Is it possible to show the black isolines in the top half of the slice as well as the bottom half without affecting the other viewports? Thanks Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 3, 2014 Share Posted March 3, 2014 Try the following. Set ISOLINES to "0". Change the color on layer HANDLE to 250. In paper space change the visual style of each viewport to Conceptual. Quote Link to comment Share on other sites More sharing options...
