Need lsp for auto ortho
sajid
I imagine that every time the OP draws a line or a polyline he wants AutoCAD to automatically assume that it will be drawn with Orthomode enabled. Think of it as an enhanced Line and/or Polyline command.
Add the following to your acaddoc.lsp:
(defun c:auto-ortho-on nil
   (if (= 'vlr-command-reactor (type auto-ortho:reactor))
       (if (not (vlr-added-p auto-ortho:reactor))
           (vlr-add auto-ortho:reactor)
       (setq auto-ortho:reactor
           (vlr-command-reactor nil
                   (:vlr-commandwillstart . auto-ortho:callback)
                   (:vlr-commandended     . auto-ortho:restore)
                   (:vlr-commandcancelled . auto-ortho:restore)
                   (:vlr-commandfailed    . auto-ortho:restore)
   (princ "\nAuto-Ortho Reactor enabled.")
(defun c:auto-ortho-off nil
       (vlr-remove auto-ortho:reactor)
   (setq auto-ortho:reactor nil)
   (princ "\nAuto-Ortho Reactor disabled.")
(defun auto-ortho:callback ( obj arg )
   (if (wcmatch (strcase (car arg) t) "line,pline")
           (setq auto-ortho:ortho (getvar 'orthomode))
           (setvar 'orthomode 1)
(defun auto-ortho:restore ( obj arg )
   (if (= 'int (type auto-ortho:ortho))
       (setvar 'orthomode auto-ortho:ortho)
   (setq auto-ortho:ortho nil)
(vl-load-com) (c:auto-ortho-on)
The reactor is enabled by default; you can then manually enable/disable the reactor using the commands: auto-ortho-on & auto-ortho-off.
Orthomode will be enabled for the LINE & PLINE commands (the commands to trigger the reactor may be customised to suit).
Lee
Edited by Lee Mac
I believe since AutoCAD 2012, once you've initiated a command (LINE, COPY, MOVE, etc) and picked your first point, hold the Shift key down and after one second, Ortho is enabled temporarily and vice versa if ORTHOMODE is 1 (enabled) it will temporarily disable Ortho. I tested in 2013 and 2014 and it works in both of those.
