Results 1 to 8 of 8
    Full Member Luís Augusto's Avatar
    Electrical
    Luís Augusto's Discipline Details
    Designer / Planner
    Electrical
    Manufacture of electrical harnesses
    AutoCAD 2010
    Apr 2012
    Botucatu, SP, Brazil
    80
    Default Sort list (Letters and Numbers)
    Hello everybody.
    I need help to sort lists in a code.
    Use a program created by the great Fixo to create tables containing some attributes. I found that, depending on how the block is built, the end result will be undesired.
    I took the liberty of attaching the file exemplifying the case.
    Any help will be appreciated.
    Luís Augusto.
    Sort list.dwg
    Code:
    ;Oleg Fateev
    ;16th Jan 2014 06:18 pm
    (defun C:CLIST
    		acapp
    		acsp
    		adoc
    		atable
    		attdata
    		attitem
    		atts
    		blkname
    		blkobj
    		col
    		en
    		headers
    		pt
    		row
    		sset
    		title
      (txtNotExists)
      (TablExists)
      (or adoc
          (setq adoc
    	     (vla-get-activedocument (setq acapp (vlax-get-acad-object)))
      (or acsp
          (setq acsp (vla-get-block (vla-get-activelayout adoc)))
      (if (setq sset (ssget	"_:S:E:L"
    			(list (cons 0 "INSERT")
    			      (cons 66 1)
    			      (cons 410 (getvar "ctab"))
          (setq en (ssname sset 0))
          (setq blkobj  (vlax-ename->vla-object en)
    	    blkname (vla-get-effectivename blkobj)
          (if (/= blkname "*");any other block different "*"
    	  (setq atts (vlax-invoke blkobj 'getattributes))
    	  (foreach attobj atts
    	    (if	(wcmatch (vla-get-tagstring attobj) "PIN_*");change "PIN_#*" use letters also
    		(setq attitem (cons (vla-get-tagstring attobj)
    				    (vla-get-textstring attobj)
    		(setq attdata (cons attitem attdata))
    	      (setq attdata (reverse attdata))
    	  (setq	attdata
    		 (mapcar '(lambda (a)
    			    (list (vl-string-subst "" "PIN_" (car a))
    				  (cdr a)
    			 attdata
    	  (if (setq pt (getpoint "\nSpecify table location:"))
    	      (setvar 'ctablestyle "TB_CONECTORS")
    	      (setq atable
    		     (vla-addtable
    		       acsp
    		       (vlax-3d-point pt)
    		       (+ 2 (length attdata))
    		       2
    		       (/ (getvar 'dimtxt) 2)
    		       (* (getvar 'dimtxt) 16)
    	      (vla-put-regeneratetablesuppressed atable :vlax-true)
    	      (setq col 0)
    	      (foreach wid (list 4.5 30.5)
    		(vla-setcolumnwidth atable col wid)
    		(setq col (1+ col))
    	      (vla-put-horzcellmargin atable 0.3)
    	      (vla-put-vertcellmargin atable 0.3)
    	      (vla-setTextheight atable 1 2.0)
    	      (vla-setTextheight atable 2 1.4)
    	      (vla-setTextheight atable 4 1.4)
    	      (setq title blkname)
    					;(setq title (getstring (strcat "\nTable title: <" blkname ">: ")))
    	      (if (eq "" title)
    	      (vla-setText atable 0 0 title)
    	      (vla-setcelltextheight atable 0 0 2.0)
    	      (vla-SetCellAlignment atable 0 0 acMiddleCenter)
    	      (setq headers
    		     (list "Pin" "Circuit / Color / Section / Mark")
    	      (setq row	1
    		    col	0
    	      (repeat (length headers)
    		(vla-SetCellAlignment atable row col acMiddleCenter)
    		(vla-setcelltextheight atable row col 1.4)
    		(vla-setText atable row col (car headers))
    		(setq headers (cdr headers))
    		(setq col (1+ col))
    	      (setq row 2)
    	      (foreach record attdata
    		(setq col 0)
    		(foreach item record
    		  (vla-setText atable row col item)
    		  (if (= 0 col)
    		    (vla-SetCellAlignment atable row col acMiddleLeft)
    		  (setq col (1+ col))
    		(setq row (1+ row))
    	      (vla-put-regeneratetablesuppressed atable :vlax-false)
    	      (vla-put-height
    		atable
    		(+ (* (vla-get-rows atable) 2.2) 4.1)
    	      (vla-update atable)
    (defun txtNotExists ()
      (if (not (tblsearch "style" "ARIAL_2.0"))
          (entmake
    	(list
    	  '(0 . "STYLE") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbTextStyleTableRecord")
    	  '(2 . "ARIAL_2.0")		;<- Your style name here
    	  '(70 . 0) '(40 . 2.0)	'(41 . 1.0) '(50 . 0.0)	'(71 . 0) '(42 . 0.09375)
    	  '(3 . "Arial.ttf") '(4 . ""))
    (defun TablExists ()
     (vl-load-com)
     (setq stylename "TB_CONECTORS")
     (setq actdoc (vla-get-activedocument (vlax-get-acad-object)))
     (setq dict (vla-get-dictionaries actdoc))
     (setq tabcol (vla-item dict "acad_tablestyle"))
     (if
          (vl-catch-all-error-p
                (setq tabsty (vl-catch-all-apply
                                   'vla-item
                                   (list tabcol stylename))))
    	    (vl-load-com)
    	    (MakeTableStyle)
    (vl-load-com)
    (defun MakeTableStyle()
    	;;http://hyperpics.blogs.com/beyond_the_ui/2012/07/creating-a-table-style-with-autolisp-and-the-activex-api.html
    	;;By Lee Ambrosius
    	;; Get the AutoCAD application and current document
        (setq acad (vlax-get-acad-object))
        (setq doc (vla-get-ActiveDocument acad))
            ;; Get the Dictionaries collection and the TableStyle dictionary
        (setq dicts (vla-get-Dictionaries doc))
        (setq dictObj (vla-Item dicts "acad_tablestyle"))
            ;; Create a custom table style
        (setq key "TB_CONECTORS" class "AcDbTableStyle")
        (setq custObj (vla-AddObject dictObj key class))
            ;; Set the name and description for the style
        (vla-put-Name custObj "TB_CONECTORS")
        (vla-put-Description custObj "Tabela de conectores")
            ;; Sets the bit flag value for the style
        (vla-put-BitFlags custObj 1)
            ;; Sets the direction of the table, top to bottom or bottom to top
        (vla-put-FlowDirection custObj acTableTopToBottom)
            ;; Sets the supression of the table header
        (vla-put-HeaderSuppressed custObj :vlax-false)
            ;; Sets the horizontal margin for the table cells
        (vla-put-HorzCellMargin custObj 0.3)
            ;; Sets the supression of the table title
        (vla-put-TitleSuppressed custObj :vlax-false)
            ;; Sets the vertical margin for the table cells
        (vla-put-VertCellMargin custObj 0.3)
            ;; Set the alignment for the Data, Header, and Title rows
        (vla-SetAlignment custObj (+ acDataRow acTitleRow) acMiddleLeft)
        (vla-SetAlignment custObj acHeaderRow acMiddleCenter)
        ;; Set the text height for the Title, Header and Data rows
        (vla-SetTextHeight custObj acTitleRow 1.5)
        (vla-SetTextHeight custObj (+ acDataRow acHeaderRow) 1.0)
            ;; Set the text height and style for the Title row
        (vla-SetTextStyle custObj (+ acDataRow acHeaderRow acTitleRow) "ARIAL_2.0")
    (prompt "\n\t---\tStart command with CLIST\t---\n")
    (prin1)
    (or (vl-load-com))
    Forum Deity pBe's Avatar
    pBe's Computer Details
    Windows 8.1
    Landscape
    AutoCAD 2015
    Apr 2010
    2,995
    maybe....
    Code:
    	      ;(setq attdata (reverse attdata))
    (setq attdata (vl-sort attdata '(lambda (x y)(< (cdr x)(cdr y)))))
    	(setq	attdata
    				  (cdr a)
    			 attdata
    Electrical
    Designer / Planner
    Electrical
    AutoCAD 2010
    Apr 2012
    80
    Perfect pBe!
    I did not understand the explanation in the documentation of Autodesk.
    I will read it again.
    Thank you very much.
    Windows 8.1
    Landscape
    AutoCAD 2015
    Apr 2010
    2,995
    Quote Originally Posted by Luís Augusto View Post
    Perfect pBe!
    ...Thank you very much.
    Cool, glad you had it "sorted" [<--- pun]
  5. #5
    Electrical
    Designer / Planner
    Electrical
    AutoCAD 2010
    Apr 2012
    80
    Hello everybody.
    pBe, I had to make a small change to the code you provided me.
    On the part of the code where it says
    Code:
    modified for
    Code:
    (setq attdata (vl-sort attdata '(lambda (x y)(< (car x)(car y)))))
    I had not noticed the problem earlier because the values ​​were within the attribute, coincided with the tag values​​.
    With the changes I made, the program began to sort by tag name. All tags whose value are letters, sorting is happening as expected, however, when ordering numbers, I get an unwanted result.
    Expected to get 1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16.
    However I get the following value, 1,10,11,12,13,14,15,16,2,3,4,5,6,7,8,9.
    Could someone help me understand and fix this problem?
    Sort list2.dwg
    Code:
    ;;   Create by Oleg Fateev (fixo)                                                       ;;
    ;;   http://www.cadtutor.net/forum/showthread.php?83991-Populate-Table                  ;;
    ;;   Modified by pBe        ;;
    ;;   http://www.cadtutor.net/forum/showthread.php?84356-Sort-list-(Letters-and-Numbers) ;;
    ;;   Modified by Luís Augusto                                                           ;;
    ;;   Table and Text Style                                                               ;;
    (defun C:CLIST
    	       (/	acapp	acsp	adoc	atable	attdata	attitem
    		atts	blkname	blkobj	col	en	headers	pt
    		row	sset	title
      (txtNotExists)
      (TablExists)
      (or adoc
          (setq adoc
      (or acsp
    			      (cons 66 1)
    		(setq attdata (cons attitem attdata)) ;(setq attdata (reverse attdata))
    				 '(lambda (x y) (< (car x) (car y))) ;Modified to car. Sorted by tag PIN.
    	  (setq	attdata
    				  (cdr a)
    			 attdata
    	      (setq atable
    		     (vla-addtable
    		       acsp
    		       (vlax-3d-point pt)
    		       2
    	      (setq col 0)
    		(setq col (1+ col))
    	      (if (eq "" title)
    	      (setq headers
    	      (setq row	1
    		    col	0
    		(setq col (1+ col))
    	      (setq row 2)
    		(setq col 0)
    		  (if (= 0 col)
    		  (setq col (1+ col))
    		(setq row (1+ row))
    	      (vla-put-height
    		atable
    	      (vla-update atable)
          (entmake
    	(list
    	  '(0 . "STYLE")
    	  '(100
    	  '(2 . "ARIAL_2.0")
    	  '(70 . 0)
    	  '(40 . 2.0)
    	  '(41 . 1.0)
    	  '(50 . 0.0)
    	  '(71 . 0)
    	  '(42 . 0.09375)
    	  '(3 . "Arial.ttf")
    	  '(4 . "")
      (vl-load-com)
      (if
    		     'vla-item
           (vl-load-com)
           (MakeTableStyle)
    (vl-load-com)
    (defun MakeTableStyle ()
      ;;By Lee Ambrosius
      ;; Obter o aplicativo AutoCAD e documento atual
      ;; Obter a coleção de dicionários e o dicionário TableStyle
      ;; Criar um estilo de tabela personalizado
      )					;(setq key "MyTableStyle" class "AcDbTableStyle")
      ;; Defina o nome e uma descrição para o estilo
      ;; Define o valor sinalizador de bits para o estilo
      ;; Define a direção da tabela, de cima para baixo ou de baixo para cima
      ;; Define a supressão do cabeçalho da tabela
      ;; Define a margem horizontal para as células da tabela
      ;; Define a supressão do título da tabela
      ;; Define a margem vertical para as células da tabela
      ;; Definir o alinhamento para as linhas de dados, cabeçalho e título
      (vla-SetAlignment
        custObj
        acMiddleLeft
      ;; Ajuste a altura do texto para as linhas Título, Cabeçalho e Dados
      ;; Ajuste a altura do texto e estilo para a linha de título
      (vla-SetTextStyle
        custObj
        "ARIAL_2.0"
    (prin1)
    (or (vl-load-com))
    Windows 8.1
    Landscape
    AutoCAD 2015
    Apr 2010
    2,995
    Question for you, Is this routine block name specific?
    "Build mode B - Numerical" and "Build mode B - Letters"?
    [see attached file]
  7. #7
    Electrical
    Designer / Planner
    Electrical
    AutoCAD 2010
    Apr 2012
    80
    Quote Originally Posted by pBe View Post
    This routine does not deal with specific names, the blocks are just one example.
    pBe,
    Many thanks for writing "_nopin" function, this solved the problem.
    Code:
    (if (wcmatch (car (car attdata)) "PIN_#*")
    	(setq
    			   '(lambda (x y)
    			      (< (_nopin (car x)) (_nopin (car y)))
    	(setq attdata
    	       (vl-sort attdata '(lambda (x y) (< (car x) (car y))))
    clist.LSP
    Best regards, Luís Augusto.
  8. #8
    Electrical
    Designer / Planner
    Electrical
    AutoCAD 2010
    Apr 2012
    80
    Update response.
    Post No. 7 was edited.
  1. filter/separate the letters/numbers
    By teknomatika in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Jun 2013, 11:57 am
  2. incrementing numbers and letters
    By JPlanera in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Jul 2012, 04:51 pm
  3. Replies: 3
    Last Post: 29th Dec 2011, 03:09 pm
  4. Automatically add letters/numbers after text
    By how do i do this? in forum AutoCAD General
    Last Post: 29th Jun 2011, 08:53 am
  5. filtering layers (containing numbers) and to ignoring letters in layer names
    By Croftyno1 in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Jun 2011, 10:28 am
Tags for this Thread
