vpatterson Posted February 3, 2014 Share Posted February 3, 2014 I need to center my text and my drop down menu, using CSS and I cannot figure it out. I have tried multiple thing and nothing is working! here is my CSS code: #menu:after {clear:both;} ul { font-family: Arial, Verdana; font-size: 14px; margin: 0; padding-bottom: 60px; list-style: none; } ul li { display: block; position: relative; float: left; } li ul { display: none; } ul li a { display: block; text-decoration: none; color: #ffffff; border-top: 1px solid #ffffff; padding: 5px 15px 5px 60px; background: #1e7c9a; margin-left: 1px; } ul li a:hover { background: #3b3b3b; } li:hover ul { display: block; position: absolute; } li:hover li { float: none; font-size: 11px; } li:hover a { background: #3b3b3b; } li:hover li a:hover { background: #1e7c9a; } And my drop down menu code: Floor Closers P-Floor Closers BP-Floor Closers A-Floor Closers F-Floor Closers H-Floor Closers Slimline-Floor Closers Over Head Conceled Closers P-Over Head Conceled Closers BP-Over Head Conceled Closers A-Over Head Conceled Closers F-Over Head Conceled Closers H-Over Head Conceled Closers Side Lites Can someone please help me? photo attached as well. Quote Link to comment Share on other sites More sharing options...
vpatterson Posted February 3, 2014 Author Share Posted February 3, 2014 The closest to center I can get is by changing the padding but it is not truly center. My new code is: .center { margin-left:36.5%; margin-right:50%; width:30%; background-color:#b0e0e6; text-align: center; vertical-align: middle; } ul { padding:0; margin:0; list-style: none; background:#000; height:36px; text-align:center } ul li { float:left; position:relative; } a:link, a:visited { text-decoration: none; color: #FFF; font-weight:bold; } ul li a, ul li a:visited { display:block; color:#fff; width:auto; height:auto; line-height:20px; padding:10px; text-align:center; } ul li a:hover { display:block; color:#000; background:#FFF; line-height:20px; padding:10px; } ul li ul, ul li:hover ul li ul { display: none; } ul li:hover ul { display:block; position:absolute; top:auto; left:0; height:auto; } ul li:hover ul li a { display:block; text-align:center; border-bottom:1px solid #FFF; } ul li:hover ul li:hover ul { display:block; position:absolute; left:124px; top:0; } Navigation code is : Floor Closers P-Floor Closers BP-Floor Closers A-Floor Closers F-Floor Closers H-Floor Closers Slimline-Floor Closers Over Head Conceled Closers P-Over Head Conceled Closers BP-Over Head Conceled Closers A-Over Head Conceled Closers F-Over Head Conceled Closers H-Over Head Conceled Closers Side Lites I need the navigation bar to be truly centered... Please HELP? Quote Link to comment Share on other sites More sharing options...
steven-g Posted February 4, 2014 Share Posted February 4, 2014 Which browser are you using, because in IE9 it looks pretty good, Chrome is another matter, I'll take a look later. In the meantime could you go back to your posts and wrap the code in code tags - it does make copying the text much easier. Quote Link to comment Share on other sites More sharing options...
vpatterson Posted February 4, 2014 Author Share Posted February 4, 2014 I am not sure what you mean by wrapping my code, but it will mainly be used in I.E. not quite sure of the version. His computer is pretty old, the site I am creating will never be hosted online, just used for easier access to the information for employees. Quote Link to comment Share on other sites More sharing options...
steven-g Posted February 4, 2014 Share Posted February 4, 2014 My new code is:.center { margin-left:36.5%; margin-right:50%; width:30%; background-color:#b0e0e6; text-align: center; vertical-align: middle; } Try swapping out the first 3 lines for a float .center { float: left; background-color:#b0e0e6; text-align: center; vertical-align: middle; } And the wrapping code means doing as I did above, use the "#" symbol when you are writing your post. It just makes things easier to read and use. Quote Link to comment Share on other sites More sharing options...
vpatterson Posted February 5, 2014 Author Share Posted February 5, 2014 That didn't work. it left aligned it. Quote Link to comment Share on other sites More sharing options...
steven-g Posted February 5, 2014 Share Posted February 5, 2014 It works fine here (which I know doesn't help you), if the computer is that old it is probably the browser that doesn't support certain parts of your code. I have attached my files just in case I did change anything else without remembering, but you might have to either try and update to a newer browser, or search for older versions of the things you are trying to do. index-html.txt style-css.txt Quote Link to comment Share on other sites More sharing options...
vpatterson Posted February 6, 2014 Author Share Posted February 6, 2014 my version of I.E. is up to date and it doesn't seem to work on mine. Its ok I shall keep the padding until I figure it out thank you for your help anyway. Quote Link to comment Share on other sites More sharing options...
