Madruga_SP Posted February 4, 2014 Share Posted February 4, 2014 Hi guys, It is really simple request. I'm trouble to finish my block, I couldn't add rotate parameter in the text's block to rotate only 180°. I can explain better my task in the attached file, take a look please. Thank in advance block test.dwg Quote Link to comment Share on other sites More sharing options...
ROBP Posted February 9, 2014 Share Posted February 9, 2014 What you needed was to add rotate command with a minimal raduis (preferably with a fixed in the middle of the multiple line of text),along with a move command with a tangent reference line in this case the vertical strech line. Please see attached. Best R [ATTACH]46760[/ATTACH] Quote Link to comment Share on other sites More sharing options...
Madruga_SP Posted February 10, 2014 Author Share Posted February 10, 2014 Hi ROBP, Thank you very much! The block is perfect. Regards Quote Link to comment Share on other sites More sharing options...
