darrellk-1 Posted February 4, 2014 Share Posted February 4, 2014 I built a dynamic block and did all the testing to insure it works correctly. I inserted it into the drawing that I built it in and it works as designed. However, when I insert it into another drawing, it is only a block. ?? Is there a option I need to turn on to let it work properly, or is there a special procedure to insert a dynamic block into a new drawing? Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 4, 2014 Share Posted February 4, 2014 Explode it. Quote Link to comment Share on other sites More sharing options...
Mike_Taylor Posted February 4, 2014 Share Posted February 4, 2014 How is the block being inserted? Is it through tool palettes? Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 4, 2014 Share Posted February 4, 2014 My guess is the OP is using the normal Insert command. Quote Link to comment Share on other sites More sharing options...
darrellk-1 Posted February 4, 2014 Author Share Posted February 4, 2014 I just learned how to create a dynamic block and do the testing during construction. Nothing was noted about how to save or insert the block into your next drawing. It was just saved in my BLOCKS file as if it were a regular block. What do I do differently? Quote Link to comment Share on other sites More sharing options...
Tuns Posted February 4, 2014 Share Posted February 4, 2014 Copy and pasta. It's the way of the 21's century. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 4, 2014 Share Posted February 4, 2014 Did you try my suggestion? Insert then Explode. Go test it now. We'll wait for your reply. Quote Link to comment Share on other sites More sharing options...
darrellk-1 Posted February 4, 2014 Author Share Posted February 4, 2014 I did the insert and exploded the block. Now I have the three blocks used to make the dynamic block. Quote Link to comment Share on other sites More sharing options...
darrellk-1 Posted February 4, 2014 Author Share Posted February 4, 2014 Do you save dynamic blocks differently than regular blocks? Maybe that is what is wrong. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 4, 2014 Share Posted February 4, 2014 No, you don't save them differently. I just tested one of my dynamic blocks and when exploded, after Insert, it functioned just as designed. Something else may be going on here. Did you copy/paste as Tuns suggested? Quote Link to comment Share on other sites More sharing options...
Mike_Taylor Posted February 4, 2014 Share Posted February 4, 2014 Are you able to post a copy of the block? Its a lot easier for us to diagnose if you do. Quote Link to comment Share on other sites More sharing options...
darrellk-1 Posted February 4, 2014 Author Share Posted February 4, 2014 Not yet. I have to recreate the dynamic block (again) and then give it a try. I'll do that now and get back to you guys. THANKS for the help so far. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 4, 2014 Share Posted February 4, 2014 Another option. Create a custom tool palette and put your dynamic block on it. Then all you need do is drag-n-drop into your new drawing. Quote Link to comment Share on other sites More sharing options...
rkent Posted February 4, 2014 Share Posted February 4, 2014 Open the block in the block editor, under open/save pick save block as, in the dialog at the bottom left check the box for, save block definition to drawing file, pick the existing name in the list, proceed from there to pick a folder and save. Now insert it from that folder. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 4, 2014 Share Posted February 4, 2014 Not yet. I have to recreate the dynamic block (again) and then give it a try. I'll do that now and get back to you guys. THANKS for the help so far. Why do you have to recreate it? I thought you saved it then tried to insert it into a new drawing. I did not want nor expect you to explode the original block! What I did expect you to do is insert the block into your new drawing THEN explode it. Quote Link to comment Share on other sites More sharing options...
darrellk-1 Posted February 4, 2014 Author Share Posted February 4, 2014 Wait, I just remembered that I saved this as a Write block so I could access it for use in other drawings. If I save it as a Block, it is only good for that one drawing, correct? How would I access it if I were not in the drawing where it was created? Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 4, 2014 Share Posted February 4, 2014 You can access your dynamic block that is in one drawing while you are in a second drawing via the Design Center. It is just a matter of dragging and dropping the block into your drawing. Have you ever used the Design Center? Yes, you should have used WBlock if your intent was to create a block that could easily be inserted into other drawings or like I said, create a custom tool palette and put your dynamic block on that. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 4, 2014 Share Posted February 4, 2014 The Design Center in action. In this example I have opened a piping diagram and asked to see the blocks contained within the drawing which appear on the right. Quote Link to comment Share on other sites More sharing options...
darrellk-1 Posted February 4, 2014 Author Share Posted February 4, 2014 I really appreciate the help, and no, I haven't used the design center except for a few times. I will work with the DC and see if that will do the trick. Thanks guys. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 4, 2014 Share Posted February 4, 2014 You were asked if you could attach a copy of your dynamic block to a post so it could be looked at by others here. Are you going to do that? Quote Link to comment Share on other sites More sharing options...
