tennis4you Posted February 6, 2014 Share Posted February 6, 2014 Is it possible with 2012LT to create a button that would automatically turn on the wipeout frames? Would be great to have a button for on and off. It's a lot to type to turn them on right now. yeah there are shortcuts, but still it's 3 things. Thanks! Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 6, 2014 Share Posted February 6, 2014 There's no system variable controlling the display of wipeout frames in LT 2012? Quote Link to comment Share on other sites More sharing options...
tennis4you Posted February 6, 2014 Author Share Posted February 6, 2014 You can turn them on to view them and then turn them off when you are done viewing them. You can set the variable to 2 to view them but not print them. In the end, we just end up turning them on and off a lot. Quote Link to comment Share on other sites More sharing options...
rkent Posted February 7, 2014 Share Posted February 7, 2014 Do you use the Ribbon? There are buttons there already for that under the Insert tab, Reference panel. Quote Link to comment Share on other sites More sharing options...
tennis4you Posted February 7, 2014 Author Share Posted February 7, 2014 Don't use the ribbons as they take up a good chunk of space, I like the classic look. Quote Link to comment Share on other sites More sharing options...
steven-g Posted February 7, 2014 Share Posted February 7, 2014 This is a simple macro to toggle a system variable between on and off, you should be able to adapt it to suit any variable (or values that you want) I use a whole load of them on a toolpalette, to switch things like - menubar - commandline - visual styles - all sorts of things ^C^C$M=$(if,$(=,$(getvar,wipeoutframe),1),wipeoutframe;0;;,wipeoutframe;1; Quote Link to comment Share on other sites More sharing options...
