+ Reply to Thread
Results 1 to 3 of 3
  1. #1
    Full Member
    Using
    AutoCAD 2011
    Join Date
    Jan 2013
    Posts
    25
    Default Special Multileader
    Hello,
    How can I create this tipe of multileader?
    Sometimes I need to use only text line 1, but sometimes I need text line 2 and 3 as well.
    I know I have to create a block and insert multileader block options in multileader type: block. But it is not working the best mode for me if I move it from right to left... I have to create a dynamic block with flip option? How can I add text lines?
    Pleas Help me if you can!
  2. #2
    Senior Member ROBP's Avatar
    Computer Details
    ROBP's Computer Details
    Operating System:
    WINDOWS 10 PRO
    Computer:
    Eurocom
    CPU:
    IINTEL i7-6700K- 4.00GHz
    RAM:
    64 GB
    Graphics:
    K5100M
    Primary Storage:
    1 TB
    Secondary Storage:
    1 TB
    Monitor:
    N/A
    Discipline
    P&ID
    ROBP's Discipline Details
    Occupation
    Powerhouse designer
    Discipline
    P&ID
    Using
    MEP 2018
    Join Date
    Oct 2013
    Location
    Montreal, Canada
    Posts
    344
    Default
    Hummmm thinking of other way to achieve it first i tend to think about changing the single line text to multine line text as far as the text goes.
    For the flip option mirror it would probably do the trick.
    with a bubble for the bubble and bubble text.
    hummmmmm i still wonder if a dynamic block is needed.
  3. #3
    Full Member
    Using
    AutoCAD 2011
    Join Date
    Jan 2013
    Posts
    25
    Default
    Thank you for the answer!
Similar Threads
  1. Special jurisdiction = special layers
    By baker in forum AutoCAD Drawing Management & Output
    Last Post: 29th Nov 2011, 06:36 pm
  2. How can I do This special shape?
    By Faouweb in forum Autodesk Inventor
    Last Post: 31st Oct 2011, 11:21 pm
  3. special commands
    By akshay92 in forum AutoCAD General
    Last Post: 20th May 2010, 03:34 pm
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
