NEWMAN1006 Posted February 11, 2014 Share Posted February 11, 2014 Is there a way to import a template (including layers) into existing dwg? we have a 2014 template but I need to use a dwg that has a ton of xref's Thanks Quote Link to comment Share on other sites More sharing options...
RobDraw Posted February 11, 2014 Share Posted February 11, 2014 You can use Design Center to get those layers or just insert the drawing as a block and delete the block afterwards. The layers will remain in the file. Quote Link to comment Share on other sites More sharing options...
NEWMAN1006 Posted February 11, 2014 Author Share Posted February 11, 2014 Thanks Rob Quote Link to comment Share on other sites More sharing options...
Tiger Posted February 11, 2014 Share Posted February 11, 2014 Since you have Civil, and if you need to move Civil-styles: You can have both drawings open at the same time, go to Settings on your Toolspace (choose Master View at the top) and Drag and drop the styles that you need - drag from the Settings-panel to the drawing area. Does pretty much the same as Design Center but for Civil stuff. Quote Link to comment Share on other sites More sharing options...
