Results 1 to 7 of 7
    Full Member
    AutoCAD 2008
    Jan 2012
    48
    Default Fence linetype missing the "x"
    So... "suddenly" my trusty 'fence' linetype ( -x-x-x-x- ) no longer displays the 'x' at the correct size ( -.-.-.-.- ). It's TINY. It's not a regular linetype scale issue as I have older untouched drawings that no longer display correctly. Also, the 'gap' where the "x" should be is showing scaled correctly, but not the tiny 'x' within. I tried re-importing the linetype from a number of local files and get the same result. Other linetypes still display correctly. It won't even appear right in the manager. Help please?
    (all lines in pic same type at different scales)
    P.S. Other computers on the same network are displaying the same issue. Files are on a central server.
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    I suppose that the "X" symbol is added like a character in linetype's definition; please check is there isn't a change in the text style used for that. I mean, the font used and/or imposed height.
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,702
    Like above
    *EXISTING_SEWER_MAIN,Existing Sewer main - - -S- - -S- - -S- - -S- - -
    A,5.08,-5.08,5.08,-5.08,["S",STANDARD,S=1.8,R=0.0,X=-1.8,Y=-.9],-3
    the text style used is standard change it to annotative and it will not work or set a height.
    Full Member
    AutoCAD 2008
    Jan 2012
    48
    Quote Originally Posted by MSasu View Post
    Quote Originally Posted by BIGAL View Post
    Like above
    Thanks. SOLVED
    I'm really rusty, and I should clarify a few things as I go. The dwg files are all on the local network. The CAD support files should be on each computer. The linetype looks fine on OTHER acads on other computers on the same network. I am using acad 2008.
    I used "new-lin.lsp" and "to-lin.lsp" (http://www.turvill.com/t2/free_stuff/index.htm) lisps to extract my current linetypes and compare to unedited originals.
    Both lisps extracted to:
    C:\Users\ME\AppData\Local\Autodesk\AutoCAD 2008\R17.1\enu\Template (<-windows search refused to find the extractions here)
    Here are two linetypes of my same 'fence' linetype:
    *Fence,--------x--------x--------x--------x
    A,1.5,-0.2,
    ["x",STANDARD,s=0.11,r=0,x=-0.1,y=-0.05],
    -0.07
    *Fence_2,----x----x----x----x
    A,0.5,-0.2,
    -0.07
    Everything was the same as the original unedited linetype data.
    I went into the same dwg on MY computer that wasn't showing correctly, AND another computer that was correct, and hit "ddstyle" to look at the "STANDARD" text style. The CORRECT computer was showing a height of "0". MY computer was showing a height something like "0.0000075754". I made mine "0", saved, reloaded, and FIXED. I'm not sure how a height of "0" makes the X appear larger than a height of "0.0000075754", but it does. I'm also not sure how this error occurred in the first place, but I'm glad it's fixed.
    Thanks again.
  5. #5
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    Quote Originally Posted by WindowsIHateYou View Post
    That is probably due to the fact that you have chosen to "Do not show hidden files or folders" in your system folder options.
    Regards,
    Mircea
  6. #6
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,146
    .... and hit "ddstyle" to look at the "STANDARD" text style. The CORRECT computer was showing a height of "0". MY computer was showing a height something like "0.0000075754". I made mine "0", saved, reloaded, and FIXED. I'm not sure how a height of "0" makes the X appear larger than a height of "0.0000075754", but it does. I'm also not sure how this error occurred in the first place, but I'm glad it's fixed.
    In the linetype definition, if the textstyle has a height of 0, then the s value is used alone to determine the height of text. If the text height is anything else then the text height is multiplied by the s value.
  7. #7
    Full Member
    AutoCAD 2008
    Jan 2012
    48
    Nope.
    Quote Originally Posted by eldon View Post
    Understood. Thanks
  1. Missing "Flat Pattern Panel" Inventor 2014
    By ConMan in forum Autodesk Inventor
    Last Post: 24th Feb 2014, 03:37 am
  2. AutoCAD object LINETYPE can be set to "BYLEVEL"?
    By SunDancer in forum AutoCAD General
    Last Post: 5th Dec 2012, 10:11 am
  3. Replies: 0
    Last Post: 27th Jul 2011, 05:30 pm
  4. Replies: 0
    Last Post: 28th Jun 2011, 07:00 pm
  5. Replies: 0
    Last Post: 21st Jan 2011, 05:20 pm
Tags for this Thread
