ssget returns nil
gpd
Dear Members
Consider the attached drawing. It contains one block and a line touching its base point. Distance between the start point of line and the base point of block is 0.0, still below lisp code returns nil. Please guide what is the reason.
(setq ss(ssget "X" (list (cons 0 "INSERT")(cons 10 spt))))
spt is the start point of the line.
Thanks.
ssget.dwg
To "see" what "Z" coordinates tharwat mentioned above
Select the block then select the line
(setq BockInsertionPoint (cdr (Assoc 10 (entget (Car (entsel))))))
(setq LineStartpoint (Vlax-curve-getstartpoint (car (entsel))))
Edited by pBe
(setq spt (getpoint)) ;[b]BLOCK -> insert point[/b]
(619827.0 2.61951e+006 [color=red]1.11028e-011[/color])
_$
[color=royalblue][b]<Selection set: 3da>[/b][/color]
_$
(setq spt (getpoint)) ;[b]POLYLINE -> end point[/b]
(619827.0 2.61951e+006 [color=red]0.0[/color])
_$
[color=royalblue][b]nil[/b] [/color]
_$
Oops...
@Tharwat & pBe
Sorry, I wrote without seeing your answers
You can use a fuzz factor:
(setq f  '(0.02 0.02 0.02)
     l  (mapcar '- spt f)
     r  (mapcar '+ spt f)
     ss (ssget "X"
               (list
                 '(0 . "INSERT")
                 '(-4 . ">,>,>")
                 (cons 10 l)
                 '(-4 . "<,<,<")
                 (cons 10 r)
The fuzz factor can be set to be equal to cursor size
(setq f (/ (* (getvar 'cursorsize) (getvar 'viewsize) 0.5)
          (cadr (getvar 'screensize))
Block properties indicate that its elevation is 0.
The values in the properties palette are rounded to the precision given by the LUPREC system variable; to see the true coordinate values to their stored precision, use the following:
(defun c:blkins ( / s )
   (if (setq s (ssget "_+.:E:S" '((0 . "INSERT"))))
       (princ
           (apply 'strcat
               (mapcar 'strcat '("\n" " " " ")
                   (mapcar
                      '(lambda ( x ) (rtos x 2 15))
                       (cdr (assoc 10 (entget (ssname s 0))))
